1
G. Ertl
Oscillatory Catalytic Reactions at Single-Crystal Surfaces
Advances in Catalysis, Volume 37, Pages 213-277 (1990)
2
You-Chang Xie, You-Qi Tang
Spontaneous Monolayer Dispersion of Oxides and Salts onto Surfaces of Supports: Applications to Heterogeneous Catalysis
Advances in Catalysis, Volume 37, Pages 1-43 (1990)
3
Luis G. Tejuca, José Luis G. Fierro, Juan M.D. Tascón
Structure and Reactivity of Perovskite-Type Oxides
Advances in Catalysis, Volume 36, Pages 237-328 (1989)
4
Gary L. Haller, Daniel E. Resasco
Metal–Support Interaction: Group VIII Metals and Reducible Oxides
Advances in Catalysis, Volume 36, Pages 173-235 (1989)
5
Michel Che, Carroll O. Bennett
The Influence of Particle Size on the Catalytic Properties of Supported Metals
Advances in Catalysis, Volume 36, Pages 55-172 (1989)
6
R.A. Van Santen, H.P.C.E. Kuipers
The Mechanism of Ethylene Epoxidation
Advances in Catalysis, Volume 35, Pages 265-321 (1987)
7
Yasuhiro Iwasawa
Chemical Design Surfaces for Active Solid Catalysts
Advances in Catalysis, Volume 35, Pages 187-264 (1987)
8
Daniel J. Driscoll, Kenneth D. Campbell, Jack H. Lunsford
Surface-Generated Gas-Phase Radicals: Formation, Detection, and Role in Catalysis
Advances in Catalysis, Volume 35, Pages 139-186 (1987)
9
Jan C.J. Bart, Gilberto Vlaic
Extended X-Ray Absorption Fine Structure Studies in Catalysis
Advances in Catalysis, Volume 35, Pages 1-138 (1987)
