主题:【分享】非常好用的核磁共振(NMR)在线词典(英文)
浏览0 回复12 电梯直达
celan
核磁共振(NMR)在线词典(英文)
NMR术语概念是按英文字母顺序排列,很好检索。
比如要查Chemical shift,点击后出现详细解释:
Chemical shift
Chemical shift, d, is the term given to the positions of the resonances in an NMR spectrum. It is cited in parts-per-million, or ppm, of frequency. The position of a resonance, in absolute frequency terms, varies with the exact field strength of the magnet used. Thus, peak positions would be instrument-dependent if they were expressed in Hz. To avoid this potentially confusing situation, the frequency of a resonance (in Hz) is divided by the resonant frequency of that nuclide. Furthermore, it is calculated as a shift, or difference, from the frequency of a chemical-shift reference compound. Thus, if a 1H peak is located 600 Hz away from the reference, and if the 1H resonant frequency on that spectrometer is 300 MHz (300,000,000 Hz), the chemical shift of the 1H peak in question is 2 ppm (600 Hz/300,000,000 Hz). On another instrument, whose 1H frequency is 600 MHz, the same 1H peak would be found 1200 Hz from the reference (1200 Hz/600,000,000 Hz).
http://arrhenius.rider.edu/nmr/NMR_tutor/dictionary/dict_intro.html#b
您可能想找: 核磁共振(NMR) 询底价
celan
该在线NMR辞典很好用,喜欢者不妨把地址添加到文件夹中,需要查阅时随时点击打开,比查书还方便。
安平
chemnmr
不错,谢谢楼主,
也推荐一个。
http://www.nmrwiki.cn
中文的,核磁方面的概念,还比较全。
celan
原文由 chemnmr(chemnmr) 发表:
不错,谢谢楼主,
也推荐一个。
中文的,核磁方面的概念,还比较全。
如果是初学NMR,建议使用http://www.nmrwiki.cn 上的概念时要多斟酌,印证。
❤厶大三
xinfeiyue
huangjujian
wyl1020
heross
赵云
