The full text of the requested document is not available in PDF format and is not currently included in the SPIE Digital Library. The document may be purchased as a hard copy and delivered via mail or fax through the SPIE Bookstore.
这是我查到的,所以应该没有电子版的材料,唉!
http://scitation.aip.org/jhtml/order_spie.jsp?cvips=PSISDG003786000001000440000001
