纯镍的话,是有点怪异,样品以前做有这情况吗? From Wikipedia, the free encyclopedia: Nickel is a silvery-white metal with a slight golden tinge that takes a high polish. It is one of only four elements that are magnetic at or near room temperature. Its Curie temperature is 355 °C. Melting point 1728 K, 1455 °C, 2651 °F Boiling point 3186 K, 2913 °C, 5275 °F
