X-Ray Source: Non-monochromated Cu Kα X-Ray
(Running condition : 40kV, 40mA)
(Rated output power: 3kW, Current and Voltage Stability: <±0.005%)
Detectors: NaI Scintillation counter detector
LynxEye 1D detector(dynamic range>1×109cps,background<0.1cps)
Optics: Both Bragg-Brentano and Parallel Beam Geometry
Gobel Mirror
Goniometer: High precision microprocessor controlled, two circle goniometer with independent stepper motors and optical encoders; Goniometer radius: ≧200mm; 2θ: -10°~168°
Smallest angular step size: 0.0001°
Reproducibility : 0.0001°
Sample Stage:Standard Stage
XYZ motorized sample stage with Vacuum Chuck
Motorizing Rotating Reflection & Transmission Sample Stage
Attachement: High Temperature MRI stage (RT-1600°C)
Low Temperature MRI stage (-180-450°C)
Application:
Phase Identification (Powder, block and Thin Film)
Phase Quantitative Analysis
Structure Refinement
Precise determination of lattice constants
Determination of crystalline size and lattice distortion
Thin Film Analysis : Roughness, Thickness(<100nm)
