2. Discussion:
A. 怎样提出观点:在提出自己的观点时,采取什么样的策略很重要,不合适的句子通常会遭到reviewer置疑。(1)如果观点不是这篇文章最新提出的,通常要用We confirm that……(2)对于自己很自信的观点,可用We believe that……(3)通常,由数据推断出一定的结论,用Results indicate, infer, suggest, imply that……(4) 在极其特别时才可用We put forward(discover, observe)……"for the first time"来强调自己的创新……(5) 如果自己对所提出的观点不完全肯定,可用We tentatively put forward (interrprete this to…)Or The results may be due to (caused by) attributed to resulted from……Or This is probably a consequence of……It seems that……can account for (interpret) this……Or It is posible that it stem from……要注意这些结构要合理搭配。如果通篇是类型1)和5),那这篇文章的意义就大打折扣。如果全是2),肯定会遭到置疑。所以要仔细分析自己成果的创新性以及可信度。
B. 连接词与逻辑:写英文论文最常见的毛病是文章的逻辑不清楚,解决方法如下。
(1)注意句子上下连贯,不能让句子独立。常见的连接词有,However, also, in addition, consequently, afterwards, moreover, Furthermore, further, although, unlike, in contrast, Similarly, Unfortunately, alternatively, parallel results, In order to, despite, For example, Compared with, other results, thus, therefore……用好连接词能使文章层次清楚,意思明确。比如,叙述有时间顺序的事件或文献,最早的文献可用AA advocated it for the first time.接下来可用Then BB further demonstrated that. 再接下来,可用Afterwards, CC……如果还有,可用More recent studies by DD……如果叙述两种观点,要把它们截然分开AA put forward that……In contrast, BB believe or Unlike AA, BB suggest or On the contrary (表明前面观点错误),如果只表明两种观点对立,用in contrast BB……如果两种观点相近,可用AA suggest……Similarily, alternatively, BB……Or Also, BB or BB allso does……表示因果或者前后关系可用Consequently, therefore, as a result……表明递进关系可用furthermore, further, moreover, in addition……写完一段英文,最好首先检查是否较好地应用了这些连接词。
(2) 注意段落布局的整体逻辑:经常我们要叙述一个问题的几个方面。这种情况下,一定要注意逻辑结构。第一段要明确告诉读者你要讨论几个部份……Therefore, there are three aspects of this problem have to be addressed. The first question involves……The second problem relates to……The third aspect deals with……清晰地把观点逐层叙述。也可以直接用First, Second, Third, Finally……当然,Furthermore, in addition等可以用来补充说明。
(3) 讨论部份的整体结构:小标题是把问题分为几个片段的好方法。通常第一个片段指出文章最重要的数据或结果;补充说明部份放在最后一个片段。一定要明白,文章的读者分为多个档次;除了本专业的专业人士读懂以外,一定要想办法能让更多的外专业人读懂。所以可以把讨论部份分为两部份,一部份提出观点,另一部份详细介绍过程以及论述的依据。这样专业外的人士可以了解文章的主要观点,比较专业的讨论他可以把它当成黑箱子,而这一部份本专业人士可以进一步研究。
C.讨论部分包括什么内容?(1)主要数据及其特征的总结;(2)主要结论及与前人观点的对比;(3) 本文的不足。对第三点,一般作者看来不可取,但事实上给出文章的不足恰恰是保护自己文章的重要手段。如果刻意隐藏文章的漏洞,觉得别人看不出来,是非常不明智的。所谓不足,包括以下内容:(1)研究的问题有点片面,讨论时一定要说,It should be noted that this study has examined only……We concentrate (focus) on only……We have to point out that we do not……Some limitations of this study are……(2)结论有些不足,The results do not imply……The results can not be used to determine(or be taken as evidence of)……Unfortunately, we can not determine this from this data……Our results are lack of……但指出这些不足之后,一定要马上再次加强本文的重要性以及可能采取的手段来解决这些不足,为别人或者自己的下一步研究打下伏笔。Not withstanding its limitation, this study does suggest……However, these problems could be solved if we consider……Despite its preliminary character, this study can clearly indicate……用中文来说这是左右逢源,把审稿人想到的问题提前给一个交代,同时表明你已经在思考这些问题,但是由于文章长度,试验进度或者试验手段的制约,暂时不能回答这些问题。但通过你的一些建议,这些问题在将来的研究中有可能实现。
3. Others:
A. 为使文章清楚,第一次提出概念时,最好以括弧给出较详细解释。如文章用了很多Abbreviation可用两种方法解决:(1) 在文章最后加上个Appendix,把所有Abbreviation列表;(2)在不同页面上不时地给出Abbreviation的含义,用来提醒读者。
B. 绝对不能全面否定前人的成果,即使在你看来前人的结论完全不对。这是对前人工作最起码的尊重,英文叫做给别人的工作credits.所以文章不要出现非常 negative的评价,比如Their results are wrong, very questionable, have no commensence, etc.遇到这类情况,可以婉转地提出:Their studies may be more reasonable if they had……considered this situation.Their results could be better convinced if they……Or Their conclusion may remain some uncertanties.
