原文由 天黑请闭眼(shxie) 发表:
【作者】:N.N. Kuznetsova, E.S. Lokteva, V.V. Lunin and S.L. Yudina.
【题名】:Hydrodechlorination of 1,1,2-trichloro-1,2,2-trifluoroethane over a nickel catalyst prepared from TiNiH{sub x}
【期刊】:Kinetics and Catalysis
【年、卷、期、起止页码】:1995年,36卷,页数:121-124
【全文链接】:暂无
很抱歉,题名和链接都没有找到,因为这个杂志的电子版是2000年之后的,或许只有纸质扫描件才行。试试看吧。
http://www.osti.gov/energycitations/product.biblio.jsp?osti_id=75550这个估计是从俄文翻译过来的,你要的这一期,国图,上海生科院,中科大都有俄文的馆藏,建议你去找到俄文的全文,然后找人帮你翻译,或者你直接google翻译吧,呵呵。检索的时候用俄文: Kinetika i Kataliz ,索要时提供俄文版的具体信息 36: No. 1, 131-135(1995)
Journal Name: Kinetics and Catalysis; Journal Volume: 36; Journal Issue: 1; Other Information: PBD: Jan-Feb 1995; TN: Translated from Kinetika i Kataliz; 36: No. 1, 131-135(1995)
Document
For copies of Journal Articles, please contact the Publisher or your local public or university library and refer to the information in the Resource Relation field.
For copies of other documents, please see the Availability, Publisher, Research Organization, Resource Relation and/or Author (affiliation information) fields and/or Document Availability.
Title Hydrodechlorination of 1,1,2-trichloro-1,2,2-trifluoroethane over a nickel catalyst prepared from TiNiH{sub x}
Creator/Author Kuznetsova, N.N. ; Lokteva, E.S. ; Lunin, V.V. ; Yudina, S.L. [Moscow State Univ. (Russian Federation)]
Publication Date 1995 Jan 01
OSTI Identifier OSTI ID: 75550
Other Number(s) Journal ID: KICAA8; ISSN 0023-1584; TRN: TRN: 95:004464-0018
Resource Type Journal Article
Resource Relation Journal Name: Kinetics and Catalysis; Journal Volume: 36; Journal Issue: 1; Other Information: PBD: Jan-Feb 1995; TN: Translated from Kinetika i Kataliz; 36: No. 1, 131-135(1995)
Subject 40 CHEMISTRY ;32 ENERGY CONSERVATION, CONSUMPTION, AND UTILIZATION ;36 MATERIALS SCIENCE; FREONS; DECHLORINATION; TITANIUM OXIDES; CATALYTIC EFFECTS; NICKEL; CHLOROFLUOROCARBONS; CATALYST SUPPORTS; NICKEL OXIDES; PH VALUE; CHEMICAL PREPARATION; MASS SPECTRA; TITANIUM HYDRIDES; NICKEL HYDRIDES
Description/Abstract Supported Ni/TiO{sub 2} catalysts are prepared by treating Ti-Ni-H{sub x} hydrides with concentrated hydrochloric acid. The catalysts were then tested in hydrodechlorination of 1,1,2-trichloro-1,2,2-trifluoroethane (freon R-113) into chlorofluoroethylene. The samples were obtained with various specific surface areas and nickel contents depending on the treatment conditions. The catalyst with 8.3% Ni and S{sub sp} = 289 m{sup 2}/g exhibits the maximal activity and stability. The effect of the strong metal-support interaction (SMSI) on the activity of the catalysts studied in hydrodechlorination is discussed.
Country of Publication United States
Language English
Format Medium: X; Size: pp. 121-124
System Entry Date 2009 Dec 16
文摘:Supported Ni/TiO{sub 2} catalysts are prepared by treating Ti-Ni-H{sub x} hydrides with concentrated hydrochloric acid. The catalysts were then tested in hydrodechlorination of 1,1,2-trichloro-1,2,2-trifluoroethane (freon R-113) into chlorofluoroethylene. The samples were obtained with various specific surface areas and nickel contents depending on the treatment conditions. The catalyst with 8.3% Ni and S{sub sp} = 289 m{sup 2}/g exhibits the maximal activity and stability. The effect of the strong metal-support interaction (SMSI) on the activity of the catalysts studied in hydrodechlorination is discussed.
或者你可以给作者写信。
