It is electrochemical migration (ECM) or electromigration. ECM is a failure mechanism that is manifested as a reduction in surface insulation resistance (SIR) of a printed circuit board (PCB). The occurrence of ECM requires an electrolyte, a voltage bias, and migrating metal.,
