原文由 wubin102628(wubin102628) 发表:
原文由 dahua1981(dahua1981) 发表:
wu版主没去nist官网上去看看吗
麻烦介绍一下?:-)
隔行如隔山啊
Welcome to the NIST Chemistry WebBookThe NIST Chemistry WebBook provides access to data compiled and distributed by NIST under the
Standard Reference Data Program.
The
NIST Chemistry WebBook contains:
- Thermochemical data for over 7000 organic and small inorganic compounds:
- Enthalpy of formation
- Enthalpy of combustion
- Heat capacity
- Entropy
- Phase transition enthalpies and temperatures
- Vapor pressure
- Reaction thermochemistry data for over 8000 reactions.
- Enthalpy of reaction
- Free energy of reaction
- IR spectra for over 16,000 compounds.
- Mass spectra for over 33,000 compounds.
- UV/Vis spectra for over 1600 compounds.
- Gas chromatography data for over 27,000 compounds.
- Electronic and vibrational spectra for over 5000 compounds.
- Constants of diatomic molecules (spectroscopic data) for over 600 compounds.
- Ion energetics data for over 16,000 compounds:
- Ionization energy
- Appearance energy
- Electron affinity
- Proton affinity
- Gas basicity
- Cluster ion binding energies
- Thermophysical property data for 74 fluids:
- Density, specific volume
- Heat capacity at constant pressure (Cp)
- Heat capacity at constant volume (Cv)
- Enthalpy
- Internal energy
- Entropy
- Viscosity
- Thermal conductivity
- Joule-Thomson coefficient
- Surface tension (saturation curve only)
- Sound speed
You can search for data on specific compounds in the Chemistry WebBook based on name, chemical formula, CAS registry number, molecular weight, chemical structure, or selected ion energetics and spectral properties.
NIST reserves the right to charge for access to this database in the future.
The National Institute of Standards and Technology (NIST) uses its best efforts to deliver a high quality copy of the Database and to verify that the data contained therein have been selected on the basis of sound scientific judgment. However, NIST makes no warranties to that effect, and NIST shall not be liable for any damage that may result from errors or omissions in the Database.
NIST statement on privacy, security, and accessibility. Click here to enter the NIST Chemistry WebBook. ©
2011 by the U.S. Secretary of Commerce on behalf of the United States of America. All rights reserved.Copyright for NIST Standard Reference Data is governed by the
Standard Reference Data Act.
