主题:【已应助】急求标准,ASTM的标准
浏览0 回复5 电梯直达
why118
急求以下标准,中、英文都行
ASTM D5261
ASTM D5199
ASTM D4595
ASTM D6241
ASTM D4533
灰米奇
ASTM D5260(Reapproved 2003)Standard Test Method for Measuring Mass per Unit Area of Geotextiles
该帖子作者被版主 fscmj2积分, 2经验,加分理由:鼓励应助
灰米奇
ASTM D 5199-2001 测定土木织物和地膜的标定厚度的试验方法
灰米奇
ASTM D4595-09 Standard Test Method for Tensile Properties of Geotextiles by the Wide-Width Strip Method
灰米奇
ASTM D 6241-99 Standard Test Method for the Static Puncture Strength of Geotextiles and Geotextile-Related Products Using a 50-mm Probe
灰米奇
ASTM D4533-04(2009)Standard Test Method for Trapezoid Tearing Strength of Geotextiles
