【作者】 朱琳; 翟美华;
【Author】 ZHU Lin ZHAI Meihua The Drug Control Institute of Nantong City in Jiangsu Province,Nantong226006,China
【机构】 江苏省南通市药品检验所;
【摘要】 目的建立抗纤胶囊的质量标准。方法采用薄层色谱法对抗纤胶囊中苦参、赤芍进行定性鉴别;采用高效
液相色谱法测定制剂中的粉防己碱,色谱柱为:Diamonsil C18柱(250mm×4.6mm,5μm)分析柱;流动相:甲醇-三乙胺溶液(3.5→500)(80∶20),流速:0.9mL·min;检测波长:283nm。结果薄层色谱法具有专属性,高效
液相色谱法准确可靠,粉防己碱在进样量0.09282~2.7846μg范围内线性关系良好,回归方程为Y=735786X-428.14,r=1.0000(n=10),平均回收率为99.11%,RSD为1.89%。结论该法可作为抗纤胶囊的质量控制标准。 更多还原
【Abstract】 Objective To establish the quality standard of Kangxian Capsules. Methods Radix Sophorae Flavescentis,Radix Paeoniae Rubra were identified by TLC.The content of tetrandrine was determined by HPLC RP.HPLC with diamonsil ODS (250 mm×4.6 mm,5 μm)column was used,The mobile phase was a mixture of methanol-trethylamine solution(3.5 → 500)(80:20)with the flow rate of 0.9 mL·min -1 and detection wavelength at 283 nm. Results TLC could identify Radix Sophorae Flavescentis,Radix Paeoniae Rubra.Tetrandrine... 更多还原
【关键词】 抗纤胶囊; 薄层色谱法; 高效
液相色谱法; 粉防己碱; 质量标准;
【Key words】 Kangxian capsule; TLC; HPLC; Tetrandrine; Quality standard;
