序号:1
作者:李期刊:CNKI
标题:典型元素单质镁和氯的高压结构及性质网址: http://www.cnki.net/KCMS/detail/detail.aspx?dbcode=CDFD&QueryID=3&CurRec=8&dbname=CDFD0911&filename=1011098870.nh&urlid=&yx=&v=MDg3NTJGeURtVUwvTFZGMjZIN094RnRuTHI1RWJQSVI4ZVgxTHV4WVM3RGgxVDNxVHJXTTFGckNVUkxtZVorZG8=
序号:2
作者:谢禹期刊:CNKI
标题:碱金属高压相变的第一性原理研究网址: http://www.cnki.net/KCMS/detail/detail.aspx?dbcode=CMFD&QueryID=3&CurRec=16&dbname=CMFD9908&filename=2007094565.nh&urlid=&yx=&v=MjE1NzdXTTFGckNVUkxtZVorZG9GeURtVUx2S1YxMjdHYk94R3RUS3FwRWJQSVI4ZVgxTHV4WVM3RGgxVDNxVHI=
序号:3
作者:高期刊:高压下典型富氢化合物结构与性质的理论研究网址: http://www.cnki.net/KCMS/detail/detail.aspx?dbcode=CDFD&QueryID=3&CurRec=17&dbname=CDFDLAST2012&filename=1012257855.nh&urlid=&yx=&v=MDAwNDFyQ1VSTG1lWitkb0Z5RG1VYnJKVkYyNkhMRzlHZG5KcXBFYlBJUjhlWDFMdXhZUzdEaDFUM3FUcldNMUY=序号:4作者:王洪波;期刊:CNKI标题:高压下含氮高能量密度材料的设计与合成网址: http://www.cnki.net/KCMS/detail/detail.aspx?dbcode=CDFD&QueryID=3&CurRec=1&dbname=CDFDLAST2013&filename=1013119336.nh&urlid=&yx=&v=MjY1MDBGckNVUkxtZVorZG9GeURtVnJ2TVZGMjZIYks1RjlMUHFaRWJQSVI4ZVgxTHV4WVM3RGgxVDNxVHJXTTE=序号:5
期刊:CNKI标题:新疆发现特大型稀有金属矿床储量超现有总储量网址: http://www.cnki.net/kcms/detail/detail.aspx?dbcode=CJFQ&dbName=CJFQ2009&FileName=XTXX200909019&v=MjY5NjLYzKaPRG2Efg99PrsfZ5hMe0x246sRNBawlES5nmfnaBch4Fq7wT0503axuB4=&uid=
