0.ALARM ICS:Instrument busy(executing M1,M2,IS,CS command) 1.ALARM# ICS:Instrument vacuum out 2.ALARM# ICS:Instrument temperature out 3.ALARM# ICS:Mains voltage out 4.ALARM# ICS:-1000 volt power supply out 5.ALARM# ICS:cabinet temperature out 6.ALARM# ICS:+5 volt power supply out 7.ALARM# ICS:+15 volt power supply out 8.ALARM# ICS:-15 volt power supply out 9.ALARM# ICS:+24 volt power supply out 10.ALARM# ICS:-100 volt power supply out 11.ALARM# ICS:-10v test out(ICS 35)/+5v SEQ out (ICS34/3520) 12.ALARM# ICS:-1v test out(ICS 35)/+15v SEQ out (ICS34/3520) 13.ALARM# ICS:-0.1v test out(ICS 35)/-15v SEQ out (ICS34/3520) 14.ALARM# ICS:charge converter zero reference out(ICS-35) 15.ALARM# ICS:CCS/DCU +350 Volt power supply out 16.ALARM# ICS:CCS/DCU +200 Volt power supply out 17.ALARM# ICS:CCS/DCU +15 Volt power supply out 18.ALARM# ICS:CCS/DCU -15 Volt power supply out 19.ALARM# ICS:CCS/DCU +5 Volt power supply out 20.ALARM# ICS:CCS/DCU +25 Volt power supply out 21.ALARM# ICS:Instrument safety circuit broken 22.ALARM# ICS:Instrument STOP button pressed 23.ALARM# ICS:Source not running 24.ALARM# ICS:Lower voltage out 25.ALARM# ICS:Charge converter overflowor underflow
