原文由 拉曼论坛(nanbowan) 发表:
参考文献里是什么实验条件,用的哪家仪器?
The experimental apparatus for Raman spectroscopy is based on a pulsed laser for excitation and a CCD array for detection. The excitation source (n i) is the 355 nm, third harmonic of a Continuum Minilight, Q-switched Nd:YAG laser having an average power of 60 mW and pulse energy of 4 mJ. The pulsewidth is 4–6 ns and the beam diameter is approximately 3 mm. The horizontally polarized laser beam is focused into the aqueous sample by a lens (100-mm focal length). The scattered intensity is collected at an angle of 90°to the direction of the source beam. A second lens focuses the radiation onto the slit of a spectrograph (100-mm slitwidth) equipped with a SpectruMM CCDTM detection system (Acton Research Corp.)
还真没找到是用的哪家仪器。。。
