主题:【讨论】研究纳米材料需要哪些仪器?
浏览0 回复11 电梯直达
futaocheng
研究纳米材料需要哪些仪器?请大家探讨一下
futaocheng
miao_zhuang
cnznn
ermao987im
cnznn
建议多看些发表的论文,那里面的研究手段很全
估计详细的书,不好找
zhengjw2001
(1) Electron microscopy (SEM and TEM).- Size and shape. If with EDX you may get compositional information.
(2) Scanning probe microscopy (AFM, STM, MFM and EFM....). Size and shape as well as force measurement.
(3) Dynamic light scattering (DLS) or Photon correlation spectroscopy (PCS) or Quasi elastic light scattering (QELS). -hydrodynamic size and Zeta potential. This tech. is good for size estimation of particle in solution.
(4) Static light scattering (Multi-angle laser light scattering, MALS).-radius of gyration. Good for protein, liposome, polymer and (Assuming we call these materials nanoparticles).
(5) Centrifugal particle sizer (CPS)- relative particle size. Has to run a internal standard first, kind of tricky.
可人
看看是制备还是分析了,制备的方法好多呢,磁控溅射,离子束溅射,溶胶凝胶等,主要就是物理沉积,化学沉积两个方面的。
a2024983
我也制备过一段时间纳米,这里给大家补充一句,我想你制备出纳米颗粒以后,最想知道的肯定是粒度了,那就先用“纳米粒度测试仪”,它起粗测的作用,等你粒度达到100nm左右了或者更小,再去做TEM
ronaldinial
chq0908
根据你的需要,一般注重纳米材料形貌的居多,先做SEM或TEM,再做XRD,Raman分析物质,根据物性测红外、紫外、荧光的,有时也会测BET和TG。
