1、根据作者E-mail地址,向作者索要。 这是最有效的方法之一。为了更方便大家向作者索取原文,但一定要简洁!一般都愿意向你提供。 下面是模板: Dear Dr. (author name): I would appreciate receiving a reprint of your article: ********(不必全写),杂志名. However, this Journal is not available in our library. Thank you very much for your consideration. Respectfully yours, Yourself name
下面是《丁香园》李天天提供的模板,也可参考。信的内容如下: Dear Mr./Mrs.: ________(作者名) I am a graduate student of Harbin Medical University in China. I major in "________"(您的专业). Recently, I found one of your articles, titled "__________" (文章名)in Medline. I found it may help me achieve my goals in this research field. This would make a really positive contribution to my work. I would like to be able to read the full text of this article. The abstract makes the article sound very interesting. I know there is usually a fee required to obtain the full article from Medline; however, as a student, my only income is a small scholarship which is about U S $30.00 per month. I wonder if you would consider sending me the full text by Email. Perhaps you would consider this as an act of friendship between our two countries. Thank you for your kind consideration of this request. Sincerely: ___________(您的名字) My Email address is: ____________________ (你的email地址) 11/16/2000
