A391/A391M-01 Standard Specification for Grade 80 Alloy Steel Chain
A392-06 Standard Specification for Zinc-Coated Steel Chain-Link Fence Fabric
A394-05e1 Standard Specification for Steel Transmission Tower Bolts, Zinc-Coated and Bare
A395/A395M-99(2004) Standard Specification for Ferritic Ductile Iron Pressure-Retaining Castings for Use at Elevated Temperatures
A400-69(2006) Standard Practice for Steel Bars, Selection Guide, Composition, and Mechanical Properties
A401/A401M-03 Standard Specification for Steel Wire, Chromium-Silicon Alloy
A403/A403M-06 Standard Specification for Wrought Austenitic Stainless Steel Piping Fittings
A407-93(2004) Standard Specification for Steel Wire, Cold-Drawn, for Coiled-Type Springs
A409/A409M-01(2005) Standard Specification for Welded Large Diameter Austenitic Steel Pipe for Corrosive or High-Temperature Service
A411-03 Standard Specification for Zinc-Coated (Galvanized) Low-Carbon Steel Armor Wire
A413/A413M-01 Standard Specification for Carbon Steel Chain
A414/A414M-06 Standard Specification for Steel, Sheet, Carbon, for Pressure Vessels
A416/A416M-06 Standard Specification for Steel Strand, Uncoated Seven-Wire for Prestressed Concrete
A417-93(2004) Standard Specification for Steel Wire, Cold-Drawn, for Zig-Zag, Square-Formed, and Sinuous-Type Upholstery Spring Units
A418/A418M-05 Standard Test Method for Ultrasonic Examination of Turbine and Generator Steel Rotor Forgings
A420/A420M-06 Standard Specification for Piping Fittings of Wrought Carbon Steel and Alloy Steel for Low-Temperature Service
A421/A421M-05 Standard Specification for Uncoated Stress-Relieved Steel Wire for Prestressed Concrete
A423/A423M-95(2004) Standard Specification for Seamless and Electric-Welded Low-Alloy Steel Tubes
A424-06 Standard Specification for Steel, Sheet, for Porcelain Enameling
A426/A426M-05 Standard Specification for Centrifugally Cast Ferritic Alloy Steel Pipe for High-Temperature Service
A427-02 Standard Specification for Wrought Alloy Steel Rolls for Cold and Hot Reduction
A428/A428M-06 Standard Test Method for Weight [Mass] of Coating on Aluminum-Coated Iron or Steel Articles
A434-06 Standard Specification for Steel Bars, Alloy, Hot-Wrought or Cold-Finished, Quenched and Tempered
A435/A435M-90(2001) Standard Specification for Straight-Beam Ultrasonic Examination of Steel Plates
A436-84(2006) Standard Specification for Austenitic Gray Iron Castings
A437/A437M-06 Standard Specification for Alloy-Steel Turbine-Type Bolting Material Specially Heat Treated for High-Temperature Service
A439-83(2004) Standard Specification for Austenitic Ductile Iron Castings
A447/A447M-93(2003) Standard Specification for Steel Castings, Chromium-Nickel-Iron Alloy (25-12 Class), for High-Temperature Service
A449-04be1 Specification for Hex Cap Screws, Bolts, and Studs, Steel, Heat Treated, 120/105/90 ksi Minimum Tensile Strength, General Use
A450/A450M-04a Standard Specification for General Requirements for Carbon, Ferritic Alloy, and Austenitic Alloy Steel Tubes
A451/A451M-06 Standard Specification for Centrifugally Cast Austenitic Steel Pipe for High-Temperature Service
A453/A453M-04 Standard Specification for High-Temperature Bolting Materials, with Expansion Coefficients Comparable to Austenitic Stainless Steels
A455/A455M-03 Standard Specification for Pressure Vessel Plates, Carbon Steel, High-Strength Manganese
A456/A456M-99(2003) Standard Specification for Magnetic Particle Examination of Large Crankshaft Forgings
A459-97(2003) Standard Specification for Zinc-Coated Flat Steel Armoring Tape
A460-94(2004)e1 Standard Specification for Copper-Clad Steel Wire Strand
A463/A463M-06 Standard Specification for Steel Sheet, Aluminum-Coated, by the Hot-Dip Process
A466/A466M-01 Standard Specification for Weldless Chain
A467/A467M-01(2006) Standard Specification for Machine and Coil Chain
A469/A469M-06 Standard Specification for Vacuum-Treated Steel Forgings for Generator Rotors
A470/A470M-05e1 Standard Specification for Vacuum-Treated Carbon and Alloy Steel Forgings for Turbine Rotors and Shafts
A471-06 Standard Specification for Vacuum-Treated Alloy Steel Forgings for Turbine Rotor Disks and Wheels
A472/A472M-05 Standard Test Method for Heat Stability of Steam Turbine Shafts and Rotor Forgings
A473-01 Standard Specification for Stainless Steel Forgings
A474-03 Standard Specification for Aluminum-Coated Steel Wire Strand
A475-03 Standard Specification for Zinc-Coated Steel Wire Strand
A476/A476M-00(2005) Standard Specification for Ductile Iron Castings for Paper Mill Dryer Rolls
A478-97(2002) Standard Specification for Chromium-Nickel Stainless Steel Weaving and Knitting Wire
A479/A479M-06a Standard Specification for Stainless Steel Bars and Shapes for Use in Boilers and Other Pressure Vessels
A480/A480M-06b Standard Specification for General Requirements for Flat-Rolled Stainless and Heat-Resisting Steel Plate, Sheet, and Strip
A481-05 Standard Specification for Chromium Metal
A482-05 Standard Specification for Ferrochrome-Silicon
A483-04 Standard Specification for Silicomanganese
A484/A484M-06b Standard Specification for General Requirements for Stainless Steel Bars, Billets, and Forgings
A485-03 Standard Specification for High Hardenability Antifriction Bearing Steel
A487/A487M-93(2003) Standard Specification for Steel Castings Suitable for Pressure Service
A488/A488M-06 Standard Practice for Steel Castings, Welding, Qualifications of Procedures and Personnel
A489-04e1 Standard Specification for Carbon Steel Lifting Eyes
A490-06 Standard Specification for Structural Bolts, Alloy Steel, Heat Treated, 150 ksi Minimum Tensile Strength
A490M-04ae1 Standard Specification for High-Strength Steel Bolts, Classes 10.9 and 10.9.3, for Structural Steel Joints [Metric]
A491-03 Standard Specification for Aluminum-Coated Steel Chain-Link Fence Fabric
A492-95(2004) Standard Specification for Stainless Steel Rope Wire
A493-95(2004) Standard Specification for Stainless Steel Wire and Wire Rods for Cold Heading and Cold Forging
A494/A494M-05 Standard Specification for Castings, Nickel and Nickel Alloy
A495-06 Standard Specification for Calcium-Silicon Alloys
A496/A496M-05 Standard Specification for Steel Wire, Deformed, for Concrete Reinforcement
A497/A497M-06e1 Standard Specification for Steel Welded Wire Reinforcement, Deformed, for Concrete
