Select not less than 30 units, and proceed as follows for the dosage form designated. Where the amount of drug substance in a single dosage unit differs from that required in the Assay, adjust the degree of dilution of the solutions and/or the volume of aliquots so that the concentration of the drug substances in the final solution is of the same order as that obtained in the Assay procedure;
