原文由 hh2222 发表:
求助标准:
MIL-S-81824“耐环境永久压接型电绝缘的铜拼接件”
AMS-DTL-23053 热缩电绝缘套管通用规则
GJB2647
万分感谢!!!!
SAE-AMS-DTL-23053 Active 5970 INSULATION SLEEVING, ELECTRICAL, HEAT SHRINKABLE, GENERAL SPECIFICATION FOR
SAE-AMS-DTL-23053/1 Active 5970 INSULATION SLEEVING, ELECTRICAL, HEAT SHRINKABLE, CROSSLINKED CHLORINATED POLYOLEFIN, FLEXIBLE
SAE-AMS-I-23053/2 Active 5970 Insulation Sleeving, Electrical, Heat Shrinkable, Polyvinyl Chloride, Flexible Crosslinked and Non-Crosslinked
SAE-AMS-I-23053/3 Active 5970 Insulation Sleeving, Electrical, Heat Shrinkable, Polyvinyl Chloride, Semi Rigid, Crosslinked and Non-Crosslinked
SAE-AMS-DTL-23053/4 Active 5970 INSULATION SLEEVING, ELECTRICAL, HEAT SHRINKABLE, POLYOLEFIN, DUAL-WALL, OUTER WALL CROSSLINKED
SAE-AMS-DTL-23053/5 Active 5970 INSULATION SLEEVING, ELECTRICAL, HEAT SHRINKABLE, POLYOLEFIN, FLEXIBLE, CROSSLINKED
SAE-AMS-DTL-23053/6 Active 5970 INSULATION SLEEVING, ELECTRICAL, HEAT SHRINKABLE, POLYOLEFIN, SEMI-RIGID, CROSSLINKED
SAE-AMS-DTL-23053/7 Active 5970 INSULATION SLEEVING, ELECTRICAL, HEAT SHRINKABLE, POLYOLEFIN, TEREPHTHALATE, NON-CROSSLINKED
SAE-AMS-DTL-23053/8 Active 5970 INSULATION SLEEVING, ELECTRICAL, HEAT SHRINKABLE, POLYVINYLIDENE FLUORIDE, SIMI-RIGID, CROSSLINKED
SAE-AMS-DTL-23053/10 Active 5970 INSULATION SLEEVING, ELECTRICAL, HEAT SHRINKABLE, SILICONE RUBBER, FLEXIBLE
SAE-AMS-DTL-23053/11 Active 5970 INSULATION SLEEVING, ELECTRICAL, HEAT SHRINKABLE, FLUORINATED ETHYLENE PROPYLENE, NON-CROSSLINKED
SAE-AMS-DTL-23053/12 Active 5970 INSULATION SLEEVING, ELECTRICAL, HEAT SHRINKABLE, POLYTETRAFLUOROETHYLENE
SAE-AMS-DTL-23053/13 Active 5970 INSULATION SLEEVING, ELECTRICAL, HEAT SHRINABLE, FLUOROELASTOMER, FLEXIBLE
SAE-AMS-DTL-23053/14 Active 5970 INSULATION SLEEVING, ELECTRICAL, HEAT SHRINKABLE, ETHYLENE-TETRAFLUOROETHYLENE FLUOROPOLYMER, SEMI-RIGID
SAE-AMS-DTL-23053/15 Active 5970 INSULATION SLEEVING, ELECTRICAL, HEAT SHRINKABLE, POLYOLEFIN, HEAVY-WALL, COATED, FLEXIBLE, OUTER WALL CROSSLINKED
SAE-AMS-DTL-23053/16 Active 5970 INSULATION SLEEVING, ELECTRICAL, HEAT SHRINKABLE, CROSSLINKED, ELASTOMERIC POLYOLEFIN, FLEXIBLE
SAE-AMS-DTL-23053/17 Active 5970 INSULATION SLEEVING, ELECTRICAL, HEAT SHRINKABLE, FLAME RETARDED, MODIFIED POLYOLEFIN, FLEXIBLE, CROSSLINKED
SAE-AMS-DTL-23053/18 Active 5970 INSULATION SLEEVING, ELECTRICAL, HEAT SHRINKABLE, MODIFIED FLUOROPOLYMER, CROSSLINKED
不知道有没有用先发六个,如果求助者感觉有用的话在CALL我,嘿嘿!
[~70456~]
[~70457~]
[~70458~]
[~70459~]
[~70460~]
[~70461~]
[~70463~]
