主题:【分享】------激光相关国标
红酒伴我醉
激光相关国标
序号Sequence No.  标准号Standard No. 中文标准名称Standard Title in Chinese 英文标准名称Standard Title in English 状态State 备注Remark
1 GB/T 20485.11-2006
振动与冲击传感器校准方法 第11部分:激光干涉法振动绝对校准 Methods for the calibration of vibration and shock transducers - Part 11: Primary vibration calibration by laser interferometry 现行 2007-02-01实施,代替GB/T 13823.2-1992
2 GB 10320-1995
激光设备和设施的电气安全 Electrical safety of laser equipment and installations 现行 1996-01-01实施,代替GB 10320-1988
3 GB 10435-1989
作业场所激光辐射卫生标准 Hygienic standard for laser radiation in the work environment 现行 1989-10-01实施
4 GB/T 11153-1989
激光小功率计性能检测方法 Parameters testing method of laser power meter in low range 现行 1990-04-01实施
5 GB/T 11293-1989
固体激光材料名词术语 Terms and definitions of solid-state laser materials 现行 1990-01-01实施
6 GB/T 11295-1989
激光晶体棒型号命名方法 Designation for laser crystal rods 现行 1990-01-01实施
7 GB/T 11297.1-2002
激光棒波前畸变的测量方法 Test method for wavefront distortion of laserrods 现行 2003-05-01实施,代替GB/T 11297.1-1989
8 GB/T 11297.2-1989
激光棒侧向散射系数的测量方法 Test method for side direction scatteringcoefficient of laser rods 现行 1990-01-01实施
9 GB/T 11297.3-2002
掺钕钇铝石榴石激光棒消光比的测量方法 Test method for extinction ratio of Nd∶YAG laser rods 现行 2003-05-01实施,代替GB/T 11297.3-1989
10 GB/T 11297.4-1989
掺钕钇铝石榴石激光棒长脉冲激光阈值及斜率效率的测量方法 Test method fornormal pulse lasing threshold and slope efficiency of Nd:YAG laser rods 现行 1990-01-01实施
11 GB/T 11297.5-1989
掺钕钇铝石榴石激光棒连续激光阈值、斜率效率和输出功率的测量方法 Test method for continuous lasing threshold, slope efficiency and output power of Nd∶YAG laser rods 现行 1990-01-01实施
12 GB 11748-2005
二氧化碳激光治疗机 Carbon dioxde Laser Treating Intrument 现行 2005-07-01实施,代替GB 11748-1999
13 GB/T 12082-1989
气体激光器文字符号 Letter symbols for gas lasers 现行 1990-07-01实施
14 GB/T 12083-1989
气体激光器电源系列 Power supply series for gas lasers 现行 1990-07-01实施
15 GB 12257-2000
氦氖激光治疗机通用技术条件 General specification of He-Ne laser medical equipment 现行 2000-12-01实施,代替GB 12257-1990
16 GB/T 12377-1990
空气中微量铀的分析方法 激光荧光法 Analytical method of microquantity uranium in air by laser-fluoremetry 现行 1990-12-01实施
17 GB/T 13739-1992
激光辐射横模鉴别方法 Testing method of transverse mode of laser radiation 现行 1993-08-01实施
18 GB/T 13740-1992
激光辐射发散角测试方法 Testing method of divergence angle of laser radiation 现行 1993-08-01实施
19 GB/T 13741-1992
激光辐射光束直径测试方法 Testing method of beam diameter of laser radiation 现行 1993-08-01实施
20 GB/T 13823.2-1992
振动与冲击传感器的校准方法 激光干涉法振动绝对校准 (一次校准) Methods for the calibration of vibration and shock pick-ups--Primary vibration calibration by laser interferometry 现行 1993-10-01实施
21 GB/T 13842-1992
掺钕钇铝石榴石激光棒 Neodymium-doped yttrium aluminium garnet laser rods 现行 1993-08-01实施
22 GB/T 13863-1992
激光辐射功率测试方法 Testing method for laser radiant power 现行 1993-05-01实施
23 GB/T 13864-1992
激光辐射功率稳定度测试方法 Testing method for laser radiant power stability 现行 1993-05-01实施
24 GB/T 14078-1993
氦氖激光器技术条件 He-Ne laser specification 现行 1993-08-01实施
25 GB/T 14128-1993
掺铷钇铝石榴石激光棒尺寸系列 Dimension series for neodymium-doped yttrium aluminium garnet laser rods 现行 1993-08-01实施
26 GB/T 15175-1994
固体激光器主要参数测试方法 Measurement methods for main parameter of solid-state lasers 现行 1995-04-01实施
27 GB/T 15301-1994
气体激光器总规范 General specification for gas lasers 现行 1995-07-01实施
28 GB/T 15313-1994
激光术语 Terminology for laser 现行 1995-10-01实施
29 GB/T 15490-1995
固体激光器总规范 General specification for solid state lasers 现行 1995-09-01实施
30 GB/T 15649-1995
半导体激光二极管空白详细规范 Blank detail specification for semiconductor laser diodes 现行 1996-04-01实施
31 GB/T 15860-1995
激光唱机通用技术条件 General specification for compact disc players 现行 1996-08-01实施
32 GB/T 16601-1996
光学表面激光损伤阈值测试方法 第1部分:1对1测试 Test methods for laser induced damage threshold of optical surfaces--Part 1: 1 on 1 test 现行 1997-04-01实施
33 GB/T 17540-1998
台式激光打印机通用规范 General specification for desktop laser printer 现行 1999-06-01实施
34 GB/T 17736-1999
激光防护镜主要参数测试方法 Testing method of main parameters for laserprotective eyewear 现行 1999-12-01实施
35 GB 18151-2000
激光防护屏 Laser guards 现行 2000-12-01实施
36 GB 18217-2000
激光安全标志 Laser safety signs 现行 2001-06-01实施
37 GB/Z 18461-2001
激光产品的安全 生产者关于激光辐射安全的检查清单 Safety of laser products--Manufacturer’s checklist for radiation safety of laser products 现行 2002-05-01实施
38 GB/Z 18462-2001
激光加工机械 金属切割的性能规范与标准检查程序 Laser processing machines--Performance specifications and benchmarks for cutting of metals 现行 2002-05-01实施
39 GB 18490-2001
激光加工机械 安全要求 Laser processing machines--Safety requirements 现行 2002-06-01实施
40 GB/T 18683-2002
钢铁件激光表面淬火 Laser surface hardening of iron and steel parts 现行 2002-08-01实施
41 GB/T 18904.2-2002
半导体器件 第12-2部分:光电子器件 纤维光学系统或子系统用带尾纤的激光二极管模块空白详细规范 Semiconductor devices--Part 12-2:Optoelectronic devices--Blank detail specification for laser diodes modules with pigtail for fiber optic systems or sub-systems 现行 2003-05-01实施
42 GB/T 19077.1-2003
粒度分析 激光衍射法 Particle size analysis--Laser diffraction method 现行 2003-09-01实施
43 GB/T 4799-2001
激光器型号命名方法 The type designation for laseres 现行 2002-05-01实施,代替GB/T 4799-1984
44 GB/T 6360-1995
激光功率能量测试仪器规范 Specification for laser radiation power and energy measuring equipment 现行 1996-01-01实施,代替GB 6360-1986
45 GB/T 6598-1986
小角激光光散射法测定聚苯乙烯标准样品的重均分子量 Determination of weight-average molecular weight of polystyrene standards by low angle laser light scattering method 现行 1987-07-01实施
46 GB 7247.1-2001
激光产品的安全 第1部分:设备分类、要求和用户指南 Safety of laser products--Part 1:Equipment classification,requirements and user’s guide 现行 2002-05-01实施,代替GB 7247-1995
47 GB/T 7257-1987
氦氖激光器参数测试方法 Measurement methods of parameter for helium neon laser 现行 1987-12-01实施
48 GB 9706.20-2000
医用电气设备 第2部分:诊断和治疗激光设备安全专用要求 Medical electrical equipment--Part 2articular requirements for the safety of diagnostic andtherapeutic laser equipment 现行 2001-05-01实施
穿越时空
