主题:【求助】(已应助)求古老文献
浏览0 回复5 电梯直达
jinjies
1. Stern, M. and Weisert, E.D.
Experimental observations on the relations between polarization resistance and corrosion rate. Proc. Amer. Sot. Test Mater. 1958, 59, 1280
2.Stern, M., Geary, A. L. (1957). ‘‘Electrochemical polarization: I. A theoretical analysis of the shape of polarization curves.’’ J. Electrochemical Soc., 104(1), 56–63.
3.Milton Stern
A Method For Determining Corrosion Rates From Linear Polarization Data
  (Corrosion, Vol. 14, No. 9, 1958, pages 440t-444t)
大陆
111 and 333 not ok.
暂无电子版可用。
Last edit by handsomeland
大陆
222 will be ok.
http://scitation.aip.org/getpdf/servlet/GetPDFServlet?filetype=pdf&id=JESOAN000104000001000056000001&idtype=cvips&prog=normal
jinjies
不能下啊,要账号的
别急,等待全文权限高的专家帮忙下。我能肯定一周内您能得到全文。--handsomeland
panyb15715
jinjies
