1.Advances in electrochemical impedance measurements in reinforced concrete.
Andrade, C Soler, L Novoa, X R
Materials Science Forum
Vol. 192-194, no. 2, pp. 843-856. 1995
http://www.scientific.net/PapersSearch.aspx?q=Advances+in+electrochemical+impedance+measurements+in+reinforced+concrete&x=15&y=142.Passivation of reinforcing steel in concrete
Andrade, C | Merino, P | Novoa, X R | Perez, M C | Soler, L
Vol. 192-194, no. 2, pp. 891-898. 1995
http://www.scientific.net/0-87849-702-1/891/
3.Corrosion rate of steel in concrete--from laboratory to reinforced structures
Elsener, B
Vol. 247, pp. 127-138. 1997
http://www.scientific.net/PapersSearch.aspx?q=Corrosion+rate+of+steel+in+concrete--from+laboratory+to+reinforced+structures+&x=25&y=144.Galvanic corrosion of steel in concrete
Alonso, M C | Andrade, C | Farina, J | Lopez, F | Merino, P | Novoa, X R
Vol. 192-194, no. 2, pp. 899-906. 1995
http://www.scientific.net/PapersSearch.aspx?q=Galvanic+corrosion+of+steel+in+concrete&x=18&y=125.Corrosion rate on reinforced concrete structures determined by electrochemical methods
Elsener, B
Vol. 192-194, no. 2, pp. 857-866. 1995
http://www.scientific.net/PapersSearch.aspx?q=Corrosion+rate+on+reinforced+concrete+structures+determined+by+electrochemical+methods&x=14&y=156.Field and laboratory experience with electrochemical methods for assessing corrosion of steel in concrete
Videm, K
Vol. 289-292, no. 1, pp. 3-14. 1998
http://www.scientific.net/PapersSearch.aspx?q=Field+and+laboratory+experience+with+electrochemical+methods+for+assessing+corrosion+of+steel+in+concrete+&x=21&y=14
