主题:【求助】有奖翻译!因本人水平有限,现译文较多,有能力译的将奖给15积分
浏览0 回复5 电梯直达
jimmyli
翻译内容:
5.3  Zip fasteners
5.3.1 Determination of the lateral strength of the  zip fastener
The velocity at which the clamps (see Figure 4)withdraw from each other is 15 cm/miin.the determination of the maximum lateral strength shall be carried out at standard atmosphere in accordance with iso 139.Prior to testing ,the zip fastener shall be equilibrated in the measuring atmosphere for at least 48h .
5.3.2 Testing of behaviour under conditions of continuous reciprocating movement shall be carried out by a device according to figure 5.
Apply a force F1 in the lateral direction and a force F2 in the longitudinal direction ,according to Table 7,to the tapes on both sides half -way between the two extreme ends of the slide .
Set and apply the test loads with the slider on the zip fastener ,at the bottom end ,and do not change them during the test.
Ensure that the opening angle of the slider tab is approximately 30 度 at the upper pointof reversal and approximately 60 度 at the lower point of reversal .When opening ,F1 may bezero.
Open and close the zip fastener 200 times by  moving the slider over a length of traverse of 7.5 cm ,a to and fro movement being designated as a test velocity of 30 strokes/min.
Subsequent to this preloading ,the maximum lateral strength of the zip fastener shall be determined according  to 5.3.1.
jimmyli
5.4 Corrosion test
    Subject the framework for  36 h to a salt spray test according to iso 7253,or for  192 h to atest according to  EN 12329.
5.5 Ground fastening
5.5.1 The ground tensioner and its fastening shall be taken from the tent fabric in the form of a strip having a width of 5 cm (three test specimens )The test specimen shall be clamped into a tensile testing machine ,with the tent fabric on one side and the ground tensioner on the other side . The lower fastening element is the peg which is hooked through the ground tensioner and fixed to the clamping device of the tensile testing machine.
The test is carried out in accordance with iso 13934-1 (with corresponding adjustment of the clamping )at a test velocity of 10 cm /min.Indicate the maximum force and record the type of failure .
5.5.2  The tensile strength shall be tested in accordance with ISO 2062.
5.6 Rain test
    TO test the requirements of  4.2.11 ,a blank test shall first be made .
prior to the rain test ,the test tent shall be subjected to asingle rain test and allowed to dry for 24 h .
The rain test is conducted as illustrated in Figure 6.
The sprinkling installation consists of
a)two sprinklers (A and B,see Figure 6 )designed as follows :
-swivelling upto  90度 maximum .
nozzle diameter 0.11 cm
angle of sprinkling 45 度,
b)sprinkling area size 500 cm  x 600 cm ,
c)water -permeable ground ,e.g.lawn.
pitch the tent in accordance with the instruction for use .Carry out the rain test with the tent closed .
Sprinkler Ashalle adjusted at such an such an angle that the foremost jet is about 20 cm in front of the tent (see Figure 6)
thetent shall first be placed with the entrance facing sprinkler A for 2 h ,then turned through aout  90度 and sprinkled for another 3 h .If further entrances of openings are proided ,they are to be placed facing sprinkler  A ,if they have a different design from the first entrance .
the water pressure shall be 3bar to  4.5 bar .The water flow rate shall be 1800 I/h.
Key
1 adjustable inclination
2 swivelling
3 large tent after turning the entrance through about 90度 away from  sprinkler A
4 small tent placed with entrance facing sprinkler A
a  For tents having a width above 500 cm ,dimension  300is reduced ,when the wide side of the tent is placed in  direction AB.
以上全部译完再加十积分共25积分.
jimmyli
以下译完奖10积分.
    Figure 6- rain test
5.7 Material connection test
    Testing shall be conduction test
    Testing shall be conducted in accordance with ISO 13934 -2 ,with the material connection at right angles to the direction of tensile load application in the middle of tthe test sample .Breaking shall occur occuroutside the material connection .
5.8 Resistance of Plastic sheets to discolouration under the effect of moisture
  The plastic sheets shall be exposed to weathering according to  ISO  105 -B04 for 24 H ,afterwards ,the sample shall be stored at standard atmosphere according to ISO 554 for 24 H,A  possible discolouation shall be evaluated on the basis of the grey scale for the assessment of colour changes  (according to ISO 105 -A 02)
jimmyli
5.9 Dimmensional stability of tents in synthetic fabrics
    Erect the tent after it has been immersed in water for  10 min.In cases where it is possible to change the tension and thus have different positions ,the alternative giving the most tautness shall be chosen .Reduce the relative humidity to (0 to 5)%
Since the temperature does not play a role in theses tests ,the temperature can be increased in order to achieve the lower relative humidity ,if necessary ,by directing a heat source at the tent .
If a heat source is used ,then the surface temperature of the tent shall not exceed 60 摄氏度.
6 Instructions for use
    Each tent shall be accompanied by instructions for use with explanatory sketches or drawings .In particular ,these instructions shall at least contain information about the following items :
a)Trial pitching of the tent (to get used to the design )
b) Choice of the site :
  -type of ground ,
  - prevailing wind direction .
c) pitching/striking :
  -information concerning the maring of the frame assembly,
  - order of pitching /striking .
  -fastening ,storm guys .
d)  Behaviour in the event of fire /means of escape :
  - advice to  occupiers  (see 4.2.19)
e) Ventilation .
f) particular problems :
  -snow ,
  - sandy soil ,
  - storms ,
  -particular environmental conditions.
g) packing :
  - folding scheme,
  - packing of wet tents (consequences )
  - separation of frame parts and canvas .
h) Maintenance /repair :
  - cleaning ,spot rmoval ,
  -storage ,
happyjyl
楼主你求助的东西太多了,估计很少有人会有时间和精力来帮你完成。建议你还是用CNKI查询专业词汇后自己翻译,有不懂的大家帮你修改。
jimmyli
