ASTM E834 - 04 Standard Practice for Determining Vacuum Chamber Gaseous Environment Using a Cold Finger
ASTM E1216 - 06 Standard Practice for Sampling for Particulate Contamination by Tape Lift
ASTM E1234 - 07 Standard Practice for Handling, Transporting, and Installing Nonvolatile Residue (NVR) Sample Plates Used in Environmentally Controlled Areas for Spacecraft
ASTM E1235 - 08 Standard Test Method for Gravimetric Determination of Nonvolatile Residue (NVR) in Environmentally Controlled Areas for Spacecraft
ASTM E1560 - 06 Standard Test Method for Gravimetric Determination of Nonvolatile Residue From Cleanroom Wipers
