原文由 sslin 发表:
楼主谈到两者的比较 "反式检测氢维(f2)分辨率较高,灵敏度较高, 缺点碳维(f1)分辨率低" 不是很精确, 因为这两者都是反式检测. 这种比较似乎应该相对于正相检测的 HETCOR 碳氢相关而言.
两者的差别主要是多量子与单量子检测, 其中涉及校高深的脉冲序列的设计.
二楼提及的小分子用 HMQC 较多的说法似乎有待商榷. 目前的一般化学结构检测的潮流似乎多趋向使用单量子 HSQC, 而一般检测的都是小分子 (分子量 500 左右).
是的。我测定的结构绝大部分是小分子,HSQC要比HMQC好些。
下面摘录:
HMQC and HSQC – 2d Heteronuclear Spectroscopy (“inverse” experiment with 1H detection)
Two sequences for measuring 1H-X chemical shift correlations, gHSQC and gHMQC are very
similar, and both will work fine for most organic compounds.
• HSQC will give sharper lines, especially for –CH2– since 1H–1H homonuclear coupling in the F1
axis is not suppressed in HMQC. HSQC is more sensitive to pulse width calibrations (has more
π-pulses), but HMQC can suffer T2 sensitivity losses in viscous and high-MW compounds.
