API 3000 文献总结
1。J Occup Health 2004: 46;49-59
Perfluorooctanoate and perfluorooctane Sulfonate Concenteations in Surface Water in Japan
日本地表水中全氟辛酸盐(PFOA)及全氟辛烷磺酸盐(PFOS)浓度测定
注:全氟辛酸盐(PFOA)及全氟辛烷磺酸盐(PFOS)为合成的表面活性剂,可导致前列腺癌,本文PFOA 及PFOS 的最低检测限分别为0.06 和0.04ng/L,最低定量限为0.1ng/L
2.Rapid Commun. Mass Spectrom. 2003; 17: 519–525
Simple and sensitive liquid chromatography/tandem mass spectrometry method for the determination of diazepam and its major metabolites in rat cerebrospinal fluid
灵敏、简单的
液相色谱串联质谱法测定鼠脑脊液中安定及其代谢物
注:4 种化合物同时测定,分析时间小于3min,取样量仅为25ml,线性范围分别为0.04–200ng/mL (安定) 0.1–200 ng/ml(安定的三种代谢物)
3.Analytical Chemistry. PAGE EST: 8.5 A-I
Determination of Saikosaponin Derivatives in Radix bupleuriand in Pharmaceuticals of the Chinese Multiherb Remedy Xiaochaihu-tang Using Liquid Chromatographic Tandem Mass Spectrometry
采用
液相色谱串联质谱法测定中药柴胡根及复方中药汤剂小柴胡汤中的柴胡皂甙衍生物
注:负离子检测,15 种柴胡皂甙衍生物的同时测定,线性范围为 1.65 或4.98 - 1200 ng/mL
4.Rapid Commun. Mass Spectrom. 2002; 16: 1844–1850
Liquid chromatograph/tandem mass spectrometry for the determination of fluoxetine and its main active metabolite norfluoxetine in human plasma with deuterated fluoxetine as internal standard
以氘代氟西汀为内标采用
液相色谱串联质谱法测定人血浆中氟西汀及其主要活性代谢物去氟西汀
注:血浆用量200ml,线性范围0.27-22ng/ml
5.Rapid Commun. Mass Spectrom. 2003; 17: 171–175
Analysis of isomeric long-chain hydroxy fatty acids by tandem mass spectrometry: application to the diagnosis of long-chain 3-hydroxyacyl CoA dehydrogenase deficiency
采用
液相色谱串联质谱法测定同分异构的长链羟基脂肪酸:在诊断长链3-羟酰基辅酶A 脱氢酶中的应用
注:新生儿筛查;血浆用量5ml,测定游离3-羟基脂肪酸含量
6.Journal of Lipid Research. Volume 46; 2005:21-26
Rapid quantification of free and esterified phytosterolsin human serum using APPI-LC-MS/MS
快速定量分析人血清中游离及脂化植物甾醇
注:APPI;同时测定谷甾醇、菜油甾醇、菜籽甾醇等4 种甾醇,线性范围1-1000ng/ml
7.Clinical Chemistry 49:2 286–294 (2003)
Determination of Choline, Betaine, and Dimethylglycine in Plasma by a High-Throughput Method Based on Normal-Phase Chromatography–Tandem Mass Spectrometry
采用高通量的
液相色谱串联质谱法同时测定血浆中的维生素B,甜菜碱和二甲基氨基乙酸
注:沉淀蛋白法,三种物质同时测定,另加两种氘代内标,分析时间3min,线性范围0.4–400mmol/L,
8.Anal. Chem.2000, 72,791-799
Collision-Induced Dissociation of Ions within the Orifice-Skimmer Region of an Electrospray Mass Spectrometer
电喷雾质谱源内碰撞诱导解离
注:在不同锥孔电压下观察到不同的溶剂加合物
9.Anal. Chem.2002, 74,1197-1201
Collection, Storage, and Filtration of in Vivo Study Samples Using 96-Well Filter Plates To Facilitate Automated Sample Preparation and LC/MS/MS Analysis
采用96 孔板采集、储存及过滤体内分析样品推进自动化样品预处理及质谱分析
注:药物候选化合物EL-A 及EL-B 线性范围为3.9-4000 ng/mL.
10.J. Mass Spectrom. 2003; 38: 879–890
A strategy for liquid chromatography/tandem mass spectrometric assays of intracellular drugs:application to the validation of the triphosphorylated anabolite of antiretrovirals in peripheral blood mononuclear cells
液相色谱串联质谱分析细胞内药物方法探索:在外周血单核细胞中逆转录病毒药物三磷酸代谢物的确认中的应用
注:抗艾滋病药,负离子检测,线性范围分别为:去羟肌苷53.39–2670 fmol/sample;司夫他定61.45–3073 fmol/sample
11.Rapid Commun. Mass Spectrom. 2003; 17: 2019–2026
Quantitation of midazolam in human plasma by automated chip-based infusion nanoelectrospray tandem mass spectrometry
采用自动chip-based infusion 纳电喷雾质谱法定量分析人血浆中的咪达唑仑
注:正离子方式检测,线性范围1.5–500 ng/mL
12.Journal of pharmaceutical sciences, VOL.91,NO.2, February 2002:405-416
Simultaneous determination of unlabeled and carbon-13-labeled etoricoxib, a new cyclooxygenase-2 inhibitor, in human plasma using HPLC-MS-MS
采用
液相色谱串联质谱法同时测定依托考昔(一种新型选择性环氧化酶2 抑制剂)及其碳13同位素标记物
注:正离子方式检测,线性范围0.5–250 ng/mL,5-2500ng/mL
13.Rapid Commun. Mass Spectrom. 2003; 17: 1950–1957
Matrix effects during analysis of plasma samples by electrospray and atmospheric pressure chemical ionization mass spectrometry: practical approaches to their elimination
血浆样品质谱分析中大气压化学离子化及电喷雾离子化基质抑制效应分析:实践方法以消除基质抑制效应
14.Anal. Chem.2000, 72,1913-1917
Automated 96-Well SPE and LC-MS-MS for Determination of Protease Inhibitors in Plasma and Cartilage Tissues
96-孔固相萃取
液相色谱串联质谱法测定血浆及软骨组织中的蛋白酶抑制剂
注:两种癌症候选化合物的线性范围分别为0.2-200 ng/mL 及0.5-300 ng/;正离子方式
15.Anal. Chem.1999, 71,2294-2300
High-Throughput Bioanalytical LC/MS/MS Determination of Benzodiazepines in Human Urine:1000 Samples per 12 hours
高通量的生物样品LC/MS/MS 分析测定人尿中苯二氮卓类化合物:每12 小时分析高达1000个样品
注:六种苯二氮卓类化合物四种内标,同时分析,每个样品分析时间仅为30 秒
