主题:【求助】(已应助)求文献11篇(还是同一期刊的,每篇10分)
浏览0 回复11 电梯直达
文文
悬赏金额:110积分 状态: 已解决
【1】Qingjie Guo, J. W. C. A.-K. E.-U. H. (2005). "Flow maldistribution at bubble cap distributor in a plant-scale circulating fluidized bed riser." AIChE Journal
51(5): 1359-1366.
【2】Raghavan, V. and D. Gidaspow (1985). "Diffusion and adsorption of moisture in desiccant sheets." AIChE Journal 31(11): 1791-1800.
【3】Rein Luus, M. J. R. X. M. M. D. G. (1975). "Letters to the editor." AIChE Journal 21(1): 207-206.
【4】Rhodes, M. J., S. Zhou, et al. (1991). "Effects of operating conditions on longitudinal solids mixing in a circulating fluidized bed riser." AIChE Journal 37(10): 1450-1458.
【5】Sanjay Dasgupta, R. J. S. S. (1994). "Turbulent gas-particle flow in vertical risers."
AIChE Journal 40(2): 215-228.
【6】Sareen, S. S., D. Gidaspow, et al. (1971). "Experimental verification of pressure profiles in fuel cell cavities." AIChE Journal 17(4): 1010-1011.
【7】Shantanu Roy, A. K. M. H. A.-D. M. P. D. (2005). "Experimental investigation of the hydrodynamics in a liquid-solid riser." AIChE Journal 51(3): 802-835.
【8】Siegel, M. H., J. C. Merchuk, et al. (1986). "Air-lift reactor analysis:Interrelationships between riser, downcomer, and gas-liquid separatorGas-Solid Flow.enl Page 3
behavior, including gas recirculation effects." AIChE Journal 32(10):
1585-1596.
【9】Solbrig, C. W. and D. Gidaspow (1967). "Convective diffusion in a rectangular duct
with one catalytic wall - laminar flow - arbitrary reaction order." AIChE Journal 13(2): 346-351.
【10】X. S. Wang, B. M. G. M. J. R. D. G. (1996). "Convective wall-to-suspension heat transfer in circulating fluidized bed risers." AIChE Journal 42(8): 2112-2117.
【11】You, J., C. Zhu, et al. (2008). "Heterogeneous structure in gas-solid riser flows."
AIChE Journal 54(6): 1459-1469.
推荐答案:dong3626回复于2008/10/13
9
补充答案:
高卧东山
高卧东山
高卧东山
高卧东山
dong3626
附件:
该帖子作者被版主 hotdoglet8积分, 2经验,加分理由:应助
dong3626
dong3626
dong3626
dong3626
dong3626
