最近需要的资料太多了,近几日求文献出去的积分太多了。不过还是很值,谢谢各位了。
[1]Jennifer, L. S. (1994). "Fluidization: Idealized and bubbleless, with applications by M. Kwauk, ellis horwood, new york, 1992, 277 pp., $85.50." AIChE Journal 40(2): 380.
[2]Leung, L. and D. Gidaspow (1974). "Iron oxide sorbents for regenerative sorption of NOx." AIChE Journal 20(5): 840-846.
[3]Lyczkowski, R. W. and D. Gidaspow (1971). "Accumulation and continuous removal of impurities in fuel cells: I. One-dimensional model." AIChE Journal 17(5):1208-1214.
[4]Lyczkowski, R. W. and D. Gidaspow (1971). "Two-dimensional inert accumulation in space hydrogen-oxygen fuel cells." AIChE Journal 17(5): 1131-1140.
[5]Lyczkowski, R. W., D. Gidaspow, et al. (1971). "Consecutive surface reactions in fully developed laminar and turbulent flow." AIChE Journal 17(2): 497-502.
[6]Marzocchella, A., R. C. Zijerveld, et al. (1997). "Chaotic behavior of gas-solids flow in the riser of a laboratory-scale circulating fluidized bed." AIChE Journal 43(6): 1458-1468.
[7]Murty, B. G. K., D. Gidaspow, et al. (1973). "Dynamics of moisture diffusion through a partially liquid filled porous matrix." AIChE Journal 19(1): 31-37.
[8]Nieuwland, J. J., M. v. S. Annaland, et al. (1996). "Hydrodynamic modeling of gas particle flows in riser reactors." AIChE Journal 42(6): 1569-1582.
[9]Pärssinen, J. H. and J. X. Zhu (2001). "Axial and radial solids distribution in a long
and high-flux CFB riser." AIChE Journal 47(10): 2197-2205.
[10]Pita, J. A. and S. Sundaresan (1993). "Developing flow of a gas-particle mixture in
a vertical riser." AIChE Journal 39(4): 541-552.
