主题:【求助】(已应助)继续求文献9篇,每篇10分
浏览0 回复11 电梯直达
文文
悬赏金额:90积分 状态: 已解决
由于囊中羞涩,需要的文献又多,只好每篇6分了。谢谢各位。
[1] Keffer, J. F.; Baines, W. D. The round turbulent jet in a cross-wind. Journal of Fluid Mechanics Digital Archive 1963, 15, (04), 481-496.
http://journals.cambridge.org//action/displayAbstract?fromPage=online&aid=369187
[2] Morsi, S. A.; Alexander, A. J. An investigation of particle trajectories in two-phase flow systems. Journal of Fluid Mechanics Digital Archive 1972, 55, (2), 193-208.
http://journals.cambridge.org//action/displayAbstract?fromPage=online&aid=384927
[3] Chassaing, P.; George, J.; Claria, A.; Sananes, F. Physical characteristics of subsonic jets in a cross-stream. Journal of Fluid Mechanics Digital Archive 1974, 62, (01), 41-64.
http://journals.cambridge.org//action/displayAbstract?fromPage=online&aid=385755
[4] Moussa, Z. M.; Trischka, J. W.; Eskinazi, S. The near field in the mixing of a round jet with a cross-stream. Journal of Fluid Mechanics Digital Archive 1977, 80, 49-80.
http://journals.cambridge.org//action/displayAbstract?fromPage=online&aid=387246
[5] Andreopoulos, J.; Wood, D. H. The response of a turbulent boundary layer to a short length of surface roughness. Journal of Fluid Mechanics Digital Archive 1982,
118, 143-164.
http://journals.cambridge.org//action/displayAbstract?fromPage=online&aid=399764
[6] Andreopoulos, J.; Rodi, W. Experimental investigation of jets in a crossflow. Journal of Fluid Mechanics Digital Archive 1984, 138, 93-127.
http://journals.cambridge.org//action/displayAbstract?fromPage=online&aid=376689
[7] Hui, K.; Haff, P. K.; Ungar, J. E.; Jackson, R. Boundary conditions for high-shear grain flows. Journal of Fluid Mechanics Digital Archive 1984, 145, 223-233.
http://journals.cambridge.org//action/displayAbstract?fromPage=online&aid=390351
[8] Lun, C. K. K.; Savage, S. B.; Jeffrey, D. J.; Chepurniy, N. Kinetic theories for granular flow: inelastic particles in Couette flow and slightly inelastic particles in a general flowfield. Journal of Fluid Mechanics Digital Archive 1984, 140, 223-256.
http://journals.cambridge.org//action/displayAbstract?fromPage=online&aid=376914
[9] Savage, S. B.; Sayed, M. Stresses developed by dry cohesionless granular materials sheared in an annular shear cell. Journal of Fluid Mechanics Digital Archive 1984, 142, 391-430.
http://journals.cambridge.org//action/displayAbstract?fromPage=online&aid=377156
推荐答案:dong3626回复于2008/10/18
补充答案:
大陆回复于2008/10/17
1篇重复了,没有权限,帮阁下补了链接。
大陆
文文
原文由 wenwen0106 发表:
由于囊中羞涩,需要的文献又多,只好每篇10分了。谢谢各位。
118, 143-164.
dong3626
dong3626
dong3626
dong3626
dong3626
dong3626
dong3626
