Claims for High-speed dispersion machine
1.Before you start dispersion machine, make sure the speed is 0.
2.Check the mixture whether there are stones or other hard things.
3.Make sure the mixer is in stable when working. Don’t work when it is shaking.
4.Don’t overload the mixture.
5.Write down the results of the experiment, shut down the power and do the clean.
