ASTM D 696-03 Standard Test Method for Coefficient of Linear Thermal Expansion of Plastics Between -30℃ and 30℃ with a Vitreous Silica Dilatometer
http://www.instrument.com.cn/bbs/download.asp?ID=59444ASTM D 2259-02 Standard Test Method for Shrinkage of Yarns
http://www.instrument.com.cn/bbs/download.asp?ID=118378ASTM C 518-04 Standard Test Method for Steady-State Thermal Transmission Properties by Means of the Heat Flow Meter Apparatus
http://www.instrument.com.cn/bbs/download.asp?ID=118382ASTM C 423-02a Standard Test Method for Sound Absorption and Sound Absorption Coefficients by the Reverberation Room Method
ASTM C 423-02aASTM E 756-04 Standard Test Method for Measuring Vibration-Damping Properties of Materials
ASTM E 756-04没有找到ASTM D 1716-1962(1974),不知道是否还存在或被其他取代?
ASTM D 1716-62(R74) 试验方法标准 硝酸纤维素分级沉淀法测定纤维素链长均匀度
