1.Crystallization and Self-Assembly of Calcium Carbonate Architectures
Junhua Xiang†, Huaqiang Cao*†‡, Jamie H. Warner‡ and Andrew A. R. Watt‡
Cryst. Growth Des., 2008, 8 (12), pp 4583–4588
http://pubs.acs.org/doi/abs/10.1021/cg8006553
2. Role of Surface/Interfacial Cu2+ Sites in the Photocatalytic Activity of Coupled CuO−TiO2 Nanocomposites
Gonghu Li†§, Nada M. Dimitrijevic‡, Le Chen†, Tijana Rajh‡ and Kimberly A. Gray*†
J. Phys. Chem. C, 2008, 112 (48), pp 19040–19044
http://pubs.acs.org/doi/abs/10.1021/jp8068392
3.Solvothermal Synthesis of V−VI Binary and Ternary Hexagonal Platelets: The Oriented Attachment Mechanism
Genqiang Zhang, Wei Wang, Xiaoli Lu and Xiaoguang Li*
Cryst. Growth Des., Article ASAP November 26, 2008
http://pubs.acs.org/doi/abs/10.1021/cg7012528
4.MoS2 Nanoribbons: High Stability and Unusual Electronic and Magnetic Properties
Yafei Li†, Zhen Zhou*†, Shengbai Zhang‡ and Zhongfang Chen*‡§
J. Am. Chem. Soc., 2008, 130 (49), pp 16739–16744
http://pubs.acs.org/doi/abs/10.1021/ja805545x
5.Mesocrystals of Rutile TiO2: Mesoscale Transformation, Crystallization, and Growth by a Biologic Molecules-Assisted Hydrothermal Process
Shu-Juan Liu, Jun-Yan Gong, Bo Hu and Shu-Hong Yu*
Cryst. Growth Des., Article ASAP: November 21, 2008
http://pubs.acs.org/doi/abs/10.1021/cg800227x
6.Au-CdS Core−Shell Nanocrystals with Controllable Shell Thickness and Photoinduced Charge Separation Property
Wei-Ta Chen, Ting-Ting Yang and Yung-Jung Hsu*
Chem. Mater., 2008, 20 (23), pp 7204–7206
http://pubs.acs.org/doi/abs/10.1021/cm802074j
7.Epitaxial graphene: a new material
physica status solidi (b)
Volume 245, Issue 7, Date: July 2008, Pages: 1436-1446
Th. Seyller, A. Bostwick, K. V. Emtsev, K. Horn, L. Ley, J. L. McChesney, T. Ohta, J. D. Riley, E. Rotenberg, F. Speck
http://www3.interscience.wiley.com/journal/119818154/abstract
8.Carbon nanotube, graphene, nanowire, and molecule-based electron and spin transport phenomena using the nonequilibrium Green's function method at the level of first principles theory
Journal of Computational Chemistry
Volume 29, Issue 7, Date: May 2008, Pages: 1073-1083
Woo Youn Kim, Kwang S. Kim
http://www3.interscience.wiley.com/journal/117859893/abstract
