主题:玻璃器皿的“Decon 90”清洗求教
浏览0 回复7 电梯直达
licuanlilili
《等离子体质谱手册》上讲“玻璃器皿可在超声槽中用5%的 Decon90 浸泡5-30分钟,用前先用1mol/L硝酸浸泡过液,再用去离水冲洗”,“Decon 90”是什么物质?哪位老师知道,请告知,谢谢!
zsdzsdzsd
自己仔细读一下了。
The leading surface active cleaning agent/radioactive
decontaminant, for laboratory, medical and
specialised industrial applications
DESCRIPTION:
Surface active cleaning agent, and/or radioactive decontaminant, for laboratory, medical and specialised industrial applications.
NOT suitable for domestic applications.
Supplied as a liquid concentrate, for dilution with water. For 憁anual?cleaning, or for use in an ultrasonic cleaning bath.
PROPERTIES:
Biodegradable *, phosphate-free, Bactericidal **, non-flammable and totally rinsable.
APPEARANCE:
Milky white, non-viscous liquid, having faint odour.
pH:
DECON 90 is alkaline. The concentrate having a pH in excess of pH 13.
PACKAGING:
Supplied in 1 litre, 5 litre and 20 litre high density polyethylene containers, with tamper-evident, screw-on caps.
APPLICATIONS:
For cleaning and/or decontaminating glassware, ceramics, rubbers, plastics, stainless steel and ferrous metals.
Being alkaline, DECON 90 is NOT suitable for use on non-ferrous metals, notably aluminium and zinc, or on polycarbonate.
FORMULATION:
An emulsion of anionic and non-ionic surface active agents, stabilising agents, non-phosphate detergent builders, alkalis and sequestering agents, in an aqueous base.
Decon 90 does NOT contain Phosphates, Enzymes, EDTA/NTA or Chlorine Bleaches.
licuanlilili
zsdzsdzsd(zsdzsdzsd)老师,谢谢你!
                李 力
zsdzsdzsd
369
你好,decon 90 是一种英国生产的清洗液,5L 800元.我是上海的一级代理,如果有需要可以打电话给我,13621990251
wutaoaa
原文由 licuanlilili 发表:
我们常用的方法是用:先用洗涤剂泡上一段时间,几个小时吧,用于去除油、脂,然后用水清洗干净,洗去泡泡。接着用1:1的浓Hcl和HNO3浸泡过夜,用去离子水洗净就可以了。这是用于ICP-MS的。
laudar
DECON 90为一种高级表面活性清洁剂/放射性污染净化剂,可用于实验室、医疗及专门工业的各种用途。
迪康90 以非黏性浓缩液体形式提供,用水进行稀释,可生物递降分解、完全可漂洗且不易燃烧。
配方:
本产品是一种由优质阴离子与非离子表面活化剂、稳定剂、碱、非磷酸盐洗涤促净剂和分隔剂合成的水基乳剂一而产生一种碱性浓缩液(PH 值为13+).
迪康90 是公认的高级实验室清洁剂,在实验室清洁应用中成功地代替了铬酸混合清洁剂。迪康90 不仅大大改进了清洁效果,而且避免了储存、处理、使用和处理腐蚀酸的各种危险,为现代实验室始终保持可靠清洁度提供了理想的解决方法。
迪康90 不包含: 酶、乙二胺醋酸/次氮基川三醋酸(EDTA「NTA)和含氯漂白剂。
适用范围:
用于玻璃制品、陶瓷制品、塑胶制品(非聚碳酸脂)、橡胶制品、不锈钢制品、铁质金属制品的完全清洗和/或污染净化,安全有效。
作为碱性物质,迪康90 不适用于非铁金属制品,特别是铝锌制品,也不适用于是聚碳酸脂制品 (迪康中性洗涤剂适用于非铁金属制品及聚碳酸脂制品)。
迪康90 使用方便,经济节省,用途十分广泛,适用于各种重要用途,具有显着的清洁及污染净化功能,而且完全可漂洗、可生物递减分解 -- 这些都是当今环境保护必各的要素。
迪康90 确定了英国乃至全世界的实验室清洁标准,被经常使用于各种试验室和各大产业,以达到现代精密技术设备所必要最佳清洁水平。迪康90 用于放射性污染净化十分有效,是实验室和企业处理放射性材料所使用最广泛的污染净化剂。迪康90 不适合家庭洗涤用途。
使用方法:
- 用水*将迪康90 稀释调配成浓度为2%至5%溶液。
- 将待清洗物浸泡2 至24 个小时,浸泡时间依污渍的顽固性及程度而定。
- 清洗严重污染物需增加溶液浓度。
- 加热溶液(40 至50 摄氏度)或使用超声波清洗池,可以大大缩短清洗时间。
- 清洗物从溶液中取出后,应立即彻底漂洗。清洗物切勿搁置太久再漂洗。建议用水*漂洗三次,以确保完全清除污染物和清洗剂的残留痕迹。
- 漂洗之后,请使用不起毛的布仔细擦干或用热气流吹干。
溶液的消耗:
没有进行确定溶液消耗量的精确检测,但当PH 值降低至8·5 时,必须更新溶液。
* 为重要用途,请始终使用脱矿质去盐水。
decon 和neutracon 为英国迪康实验室有报公司(Decon LaboratoriesLimited,U·K)在英国以及国外的注册商标。
目前上海地区总代理请找:
上海泰玛科技有限公司
电话:021-62603990,62220568
E-mail:wang.robin2007@yahoo.com.cn
联系人:王先生
公司长期备有大量现货!上海地区送货上门!!!
fish380142
请问decon 90这种试剂是用于有机和无机清洗都可以的吗?
