【正题名】: Prediction of ASTM Method D86 Distillation of Gasolines and Naphthas according to the Fugacity-Filmmodel from Gas Chromatographic Detailed Hydocarbon Analysis 【作者】: Walter Spieksma 【作者单位】:AC Analytical Controls, /Rotterdam, the Netherlands 【刊名】: Journal of Chromatographic Science 【年卷期】: 1998.36.1-12 【出版年】: 1998 【ISSN】: 0021-9665 【页码】: p.467-475 【分类号】: O65 【正文语种】: eng 【文摘语种】: eng 【文摘】:Light refinery streams and finished gasolines are analyzed with different gas chromatography methods. Kováts indices and mole fractions of the components are used to determine physico-chemical properties. These properties are used in the fugacity-filmmodel, obtained from the combination of Fick's Law and Henry's Law. Calculated temperature/volume data are compared with experimental data from the 1996 80-laboratory crosscheck of ASTM D86 distillation within the standard deviation. http://www.j-chrom-sci.com/abstracts/1998/september/spieksma.htm
