1H/1H-NOESY (NOE correlation spectroscopy) detects intra- and intermolecular spatial proximity (via direct coupling) among protons and allows to establish the corresponding dipolar network most efficiently. The same experiment (EXCSY) may be used to detect chemical and dynamic exchange among protons. Ref.: J. Jeener, B.H. Meier, P. Bachmann, R.R. Ernst, J. Chem. Phys. 71, 4546-4563 1979 D.J. States, R.A. Haberkorn, D.J. Ruben, J. Magn. Reson. 48, 286-292 1982 Note:· · NOEs are dependent on molecular size and tumbling rates characterized by correlation times. For small molecules NOEs are positive (with a maximum of +0.385); for large (bio-)molecules NOEs are negative (with a maximum of –1.0). For molecules of intermediate size NOEs may be close to zero even for closely spaced protons. The ROESY experiment is used in such situations. · · so-called transient NOEs are measured, in contrast to the stronger steady-state NOEs obtained with the 1D NOE experiment.
1H/1H-ROESY (ROE correlation spectroscopy) detects intra- and intermolecular spatial proximity (via direct coupling) among protons and allows to establish the corresponding dipolar network most efficiently. The same experiment may be used to detect chemical and dynamic exchange among protons. Ref.: A. A. Bothner-By, R.L. Stephens, J.-M. Lee, C.D. Warren, R.W. Jeanloz, J. Am. Chem. Soc. 106, 811-813 1984 A. Bax, D.G. Davis, J. Magn. Reson. 63, 207-213 1985 Note: · · in contrast to the NOESY experiment with the NOE built up under the influence of the strong static magnetic field, ROEs are built up in the much weaker “rotating field”. As a consequence ROEs are positive throughout (no zero-crossing) irrespective of the molecular size, but yield weaker effects for large molecules (<0.7 compared to –1.0 for NOEs) · · so-called transient ROEs are measured, in contrast to the stronger steady-state NOEs obtained with the 1D NOE experiment.
