序号:1
标题:Influence of thermal cycling on structural, optical and electrical properties of vanadium oxide thin films
作者:Xiaochun Wu,Fachun Lai,Limei Lin,Yongzeng Li,Lianghui Lin,Yan Qu, Zhigao Huang
期刊:Applied Surface Science, Volume 255, Issue 5, Part 2, 30 December 2008, Pages 2840-2844
全文链接:http://www.sciencedirect.com/science?_ob=ArticleURL&_udi=B6THY-4T9M5Y1-7&_user=10&_coverDate=12%2F30%2F2008&_alid=903321374&_rdoc=1&_fmt=high&_orig=search&_cdi=5295&_docanchor=&view=c&_ct=1&_acct=C000050221&_version=1&_urlVersion=0&_userid=10&md5=16b0089d25cf5af9dc43b15adeb48219
序号:2
标题:Field emission properties of DLC and phosphorus-doped DLC films prepared by electrochemical deposition process
作者:Shanhong Wan,Liping Wang,Junyan Zhang,Qunji Xue
期刊:"Applied Surface Science, Volume 255, Issue 6, 1 January 2009, Pages 3817-3821
全文链接:http://www.sciencedirect.com/science?_ob=ArticleURL&_udi=B6THY-4TT9G9X-1&_user=10&_coverDate=01%2F01%2F2009&_alid=903322070&_rdoc=1&_fmt=high&_orig=search&_cdi=5295&_sort=d&_docanchor=&view=c&_ct=1&_acct=C000050221&_version=1&_urlVersion=0&_userid=10&md5=04049cb2bad7165cbbbf6517dd919b0a
序号:3
标题:Effect of TiO2 buffer layer on the structural and optical properties of ZnO thin films deposited by E-beam evaporation and sol–gel method
作者:Linhua Xu a,Linxing Shi, Xiangyin Li
期刊:Applied Surface Science, Volume 255, Issue 5, Part 2, 30 December 2008, Pages 3230-3234
全文链接:http://www.sciencedirect.com/science?_ob=ArticleURL&_udi=B6THY-4TGHN5N-2&_user=10&_coverDate=12%2F30%2F2008&_alid=903321568&_rdoc=1&_fmt=high&_orig=search&_cdi=5295&_sort=d&_docanchor=&view=c&_ct=1&_acct=C000050221&_version=1&_urlVersion=0&_userid=10&md5=a829225eb9a05b8d06feca3786d8dce2
序号:4
标题:A novel method to fabricate superhydrophobic surfaces based on well-defined mulberry-like particles and self-assembly of polydimethylsiloxane
作者:Jinxin Yang,Pihui Pi,Xiufang Wen,Dafeng Zheng,Mengyi Xu,Jiang Cheng,Zhuoru Yang
期刊:"Applied Surface Science, Volume 255, Issue 6, 1 January 2009, Pages 3507-3512
全文链接:http://www.sciencedirect.com/science?_ob=ArticleURL&_udi=B6THY-4TPPDVB-1&_user=10&_coverDate=01%2F01%2F2009&_alid=903322344&_rdoc=1&_fmt=high&_orig=search&_cdi=5295&_sort=d&_docanchor=&view=c&_ct=1&_acct=C000050221&_version=1&_urlVersion=0&_userid=10&md5=c4bcb00839a46336be3c0dba977f9c20
序号:5
标题:Microtribological properties of molecularly thin carboxylic acid functionalized imidazolium ionic liquid film on single-crystal silicon
作者:Yufei Mo,Bo Yu,Wenjie Zhao,Mingwu Bai
期刊:Applied Surface Science, Volume 255, Issue 5, Part 1, 30 December 2008, Pages 2276-2283
全文链接:http://www.sciencedirect.com/science?_ob=ArticleURL&_udi=B6THY-4T1Y3K5-1&_user=10&_coverDate=12%2F30%2F2008&_alid=903323204&_rdoc=1&_fmt=high&_orig=search&_cdi=5295&_sort=d&_docanchor=&view=c&_ct=1&_acct=C000050221&_version=1&_urlVersion=0&_userid=10&md5=184f0cc6b0f8fca523cdcfe90beab54d
序号:6
标题:Effect of air-jet texturing on adhesion behaviour of polyester yarns to rubber
作者:Serpil Koral Koc,Asli Sengonul Hockenberger,Qufu Wei
期刊:Applied Surface Science, Volume 254, Issue 21, 30 August 2008, Pages 7049-7055
全文链接:http://www.sciencedirect.com/science?_ob=ArticleURL&_udi=B6THY-4SKB37C-1&_user=10&_coverDate=08%2F30%2F2008&_alid=903322642&_rdoc=1&_fmt=high&_orig=search&_cdi=5295&_sort=d&_docanchor=&view=c&_ct=1&_acct=C000050221&_version=1&_urlVersion=0&_userid=10&md5=25b2ba0f3c63b3c781181c7f3474b25e
序号:7
标题:A ring area formed around the erosion pit on 1Cr18Ni9Ti stainless steel surface in incipient cavitation erosion
作者:Chen Haosheng,Li Jiang
期刊:Wear, Volume 266, Issues 7-8, 25 March 2009, Pages 884-887
全文链接:http://www.sciencedirect.com/science?_ob=ArticleURL&_udi=B6V5B-4TGY408-1&_user=10&_coverDate=03%2F25%2F2009&_alid=903323412&_rdoc=1&_fmt=high&_orig=search&_cdi=5782&_sort=d&_docanchor=&view=c&_ct=1&_acct=C000050221&_version=1&_urlVersion=0&_userid=10&md5=15b84c35fb781afcdcfe76f826134dbb
序号:8
标题:Cavitation damages on solid surfaces in suspensions containing spherical and irregular microparticles
作者:Chen Haosheng,Wang Jiadao,Chen Darong
期刊:Wear, Volume 266, Issues 1-2, 5 January 2009, Pages 345-348
全文链接:http://www.sciencedirect.com/science?_ob=ArticleURL&_udi=B6V5B-4SXS36V-2&_user=10&_coverDate=01%2F05%2F2009&_alid=903323520&_rdoc=1&_fmt=high&_orig=search&_cdi=5782&_sort=d&_docanchor=&view=c&_ct=1&_acct=C000050221&_version=1&_urlVersion=0&_userid=10&md5=115befd71b5e1e30e82d898959d02e91
序号:9
标题:Inelastic damages by stress wave on steel surface at the incubation stage of vibration cavitation erosion
作者:Chen Haosheng,Liu Shihan
期刊:Wear, Volume 266, Issues 1-2, 5 January 2009, Pages 69-75
全文链接:http://www.sciencedirect.com/science?_ob=ArticleURL&_udi=B6V5B-4SXS36V-1&_user=10&_coverDate=01%2F05%2F2009&_alid=903324404&_rdoc=1&_fmt=high&_orig=search&_cdi=5782&_sort=d&_docanchor=&view=c&_ct=1&_acct=C000050221&_version=1&_urlVersion=0&_userid=10&md5=7f39c22d6d7b7cd0219fec304182d54c
序号:10
标题:Effect of K-doping on structural and optical properties of ZnO thin films
作者:Linhua Xu, Xiangyin Li, Jun Yuan
期刊:Superlattices and Microstructures, Volume 44, Issue 3, September 2008, Pages 276-281
全文链接:http://www.sciencedirect.com/science?_ob=ArticleURL&_udi=B6WXB-4T1SKD2-1&_user=10&_coverDate=09%2F30%2F2008&_alid=903325177&_rdoc=1&_fmt=high&_orig=search&_cdi=7154&_sort=d&_docanchor=&view=c&_ct=1&_acct=C000050221&_version=1&_urlVersion=0&_userid=10&md5=cee75e6111615101355bc24ca939113e
