主题:【求助】翻译CGMP中的一句话
浏览0 回复3 电梯直达
立静致远
cGMP “Regulations set forth that contain the minimum methods to be used in, and control to be used for, the manufacture, processing, packaging, or holding of a drug to assure that such drug meets the requirements of the act as to safety, and has the identity and strength and meets the quality and purity characteristics that is represented to possess.”
mao0757
包含用在生产、处理、包装、储存等过程中的细微测试方法及控制手段的法规是用来确保此药物安全,且保证药物质量和纯度满足规定,药效好。
该帖子作者被版主 redanqi5积分, 2经验,加分理由:应助
poorlittle
原文由 mao0757 发表:
minimum methods 似是 “最起码的方法”
粤语中有“最起码”一说, 不知书面语是否一样。  minimum methods大意是可接受条伴下最低要求的方法。
Last edit by poorlittle
何当奇
原文由 poorlittle 发表:
原文由 mao0757 发表:
我觉得确实有最起码的方法的意思,但是也许翻译为 基本分析方法会更好点的
