(A)After finding of infringement. An applicant who has submitted a certification under paragraph (a)(12)(i)(A)(4 ) of this section and is sued for patent infringement within 45 days of the receipt of notice sent under 314.95 shall amend the certification if a final judgment in the action against the applicant is entered finding the patent to be infringed. In the amended certification, the applicant shall certify under paragraph (a)(12)(i)(A)(3 ) of this section that the patent will expire on a specific date. Once an amendment or letter for the change has been submitted, the application will no longer be considered to be one containing a certification under paragraph (a)(12)(i)(A)(4 ) of this section. If a final judgment finds the patent to be invalid and infringed, an amended certification is not required.
(B)After removal of a patent from the list. If a patent is removed from the list, any applicant with a pending application (including a tentatively approved application with a delayed effective date) who has made a certification with respect to such patent shall amend its certification. The applicant shall certify under paragraph (a)(12)(ii) of this section that no patents described in paragraph (a)(12)(i) of this section claim the drug or, if other relevant patents claim the drug, shall amend the certification to refer only to those relevant patents. In the amendment, the applicant shall state the reason for the change in certification (that the patent is or has been removed from the list). A patent that is the subject of a lawsuit under 314.107(c) shall not be removed from the list until FDA determines either that no delay in effective dates of approval is required under that section as a result of the lawsuit, that the patent has expired, or that any such period of delay in effective dates of approval is ended. An applicant shall submit an amended certification. Once an amendment or letter for the change has been submitted, the application will no longer be considered to be one containing a certification under paragraph (a)(12)(i)(A)(4) of this section.
(C)Other amendments. (1 ) Except as provided in paragraphs (a)(12)(vi) and (a)(12)(viii)(C)(2 ) of this section, an applicant shall amend a submitted certification if, at any time before the effective date of the approval of the application, the applicant learns that the submitted certification is no longer accurate.
(2 ) An applicant is not required to amend a submitted certification when information on a patent on the listed drug is submitted after the effective date of approval of the abbreviated application.
(13)Financial certification or disclosure statement. An abbreviated application shall contain a financial certification or disclosure statement as required by part 54 of this chapter.
(b)Drug products subject to the Drug Efficacy Study Implementation (DESI) review. If the abbreviated new drug application is for a duplicate of a drug product that is subject to FDA's DESI review (a review of drug products approved as safe between 1938 and 1962) or other DESI-like review and the drug product evaluated in the review is a listed drug, the applicant shall comply with the provisions of paragraph (a) of this section.
(c) [Reserved]
(d)Format of an abbreviated application. (1) The applicant must submit a complete archival copy of the abbreviated application as required under paragraphs (a) and (c) of this section. FDA will maintain the archival copy during the review of the application to permit individual reviewers to refer to information that is not contained in their particular technical sections of the application, to give other agency personnel access to the application for official business, and to maintain in one place a complete copy of the application.
(i)Format of submission. An applicant may submit portions of the archival copy of the abbreviated application in any form that the applicant and FDA agree is acceptable, except as provided in paragraph (d)(1)(ii) of this section.
(ii)Labeling. The content of labeling required under 201.100(d)(3) of this chapter (commonly referred to as the package insert or professional labeling), including all text, tables, and figures, must be submitted to the agency in electronic format as described in paragraph (d)(1)(iii) of this section. This requirement applies to the content of labeling for the proposed drug product only and is in addition to the requirements of paragraph (a)(8)(ii) of this section that copies of the formatted label and all proposed labeling be submitted. Submissions under this paragraph must be made in accordance with part 11 of this chapter, except for the requirements of 11.10(a), (c) through (h), and (k), and the corresponding requirements of 11.30.
(iii)Electronic format submissions. Electronic format submissions must be in a form that FDA can process, review, and archive. FDA will periodically issue guidance on how to provide the electronic submission (e.g., method of transmission, media, file formats, preparation and organization of files).
(2) For abbreviated new drug applications, the applicant shall submit a review copy of the abbreviated application that contains two separate sections. One section shall contain the information described under paragraphs (a)(2) through (a)(6), (a)(8), and (a)(9) of this section 505(j)(2)(A)(vii) of the act and one copy of the analytical procedures and descriptive information needed by FDA's laboratories to perform tests on samples of the proposed drug product and to validate the applicant's analytical procedures. The other section shall contain the information described under paragraphs (a)(3), (a)(7), and (a)(8) of this section. Each of the sections in the review copy is required to contain a copy of the application form described under 314.50(a).
(3) [Reserved]
(4) The applicant may obtain from FDA sufficient folders to bind the archival, the review, and the field copies of the abbreviated application.
(5) The applicant shall submit a field copy of the abbreviated application that contains the technical section described in paragraph (a)(9) of this section, a copy of the application form required under paragraph (a)(1) of this section, and a certification that the field copy is a true copy of the technical section described in paragraph (a)(9) of this section contained in the archival and review copies of the abbreviated application.
[57 FR 17983, Apr. 28, 1992; 57 FR 29353, July 1, 1992, as amended at 58 FR 47352, Sept. 8, 1993; 59 FR 50364, Oct. 3, 1994; 63 FR 5252, Feb. 2, 1998; 63 FR 66399, Dec. 1, 1998; 64 FR 401, Jan. 5, 1999; 65 FR 56479, Sept. 19, 2000; 67 FR 77672, Dec. 19, 2002; 68 FR 69019, Dec. 11, 2003; 69 FR 18766, Apr. 8, 2004]
