原文由 H7711 发表:
I need to run my spectrum at a higher field to get better resolution.
No you don't! The resolution of a high field spectrometer may even be worse than a low field spectrometer.
Some nuclei such as 31P may have worse resolution because of a property called chemical shift anisotropy which increases with field strength.
