请帮忙查以下文献,感谢!
1. Synthesis, Characterization, and Electroluminescence of Polyfluorene Copolymers with Phenothiazine Derivative; Their Applications to High-Efficiency Red and White PLEDs
Moo-Jin Park†, Jonghee Lee‡§, In Hwan Jung‡, Jong-Hwa Park‡, Do-Hoon Hwang* and Hong-Ku Shim*‡
Macromolecules, 2008, 41 (24), pp 9643–9649
http://pubs.acs.org/doi/abs/10.1021/ma802043q?prevSearch=PLED&searchHistoryKey=
2.Performance Enhancement of Polymer Light-Emitting Diodes by Using Ultrathin Fluorinated Polyimide Modifying the Surface of Poly(3,4-ethylene dioxythiophene):Poly(styrenesulfonate)
Baohua Zhang†‡, Wenmu Li†‡, Junwei Yang†, Yingying Fu†‡, Zhiyuan Xie*†, Suobo Zhang† and Lixiang Wang†
J. Phys. Chem. C, 2009, 113 (18), pp 7898–7903
http://pubs.acs.org/doi/abs/10.1021/jp810824m?prevSearch=PLED&searchHistoryKey=
3.Toward Thermally, Oxidatively, and Spectrally Stable Polyfluorene-Based Materials: Aromatic Ether-Functionalized Polyfluorene
Shaune L. McFarlane†, Davin G. Piercey†, Leah S. Coumont†, Ryan T. Tucker‡, Michael D. Fleischauer§, Michael J. Brett‡§ and Jonathan G. C. Veinot*†
http://pubs.acs.org/doi/abs/10.1021/ma8022348?prevSearch=PLED&searchHistoryKey=
4. White Hybrid Organic−Inorganic Light-Emitting Diode Using ZnO as the Air-Stable Cathode
Henk J. Bolink*, Eugenio Coronado and Michele Sessolo
Chem. Mater., 2009, 21 (3), pp 439–441
http://pubs.acs.org/doi/abs/10.1021/cm8031362?prevSearch=PLED&searchHistoryKey=
5.New Indole-Based Light-Emitting Oligomers: Structural Modification, Photophysical Behavior, and Electroluminescent Properties
Qianqian Li†, Jianhua Zou‡, Junwu Chen‡, Zijun Liu†, Jingui Qin†, Zhen Li†* and Yong Cao‡
J. Phys. Chem. B, 2009, 113 (17), pp 5816–5822
http://pubs.acs.org/doi/abs/10.1021/jp9005372?prevSearch=PLED&searchHistoryKey=
6.Post Doping by Wet Deposition Process in Polymer Light-Emitting Diode Fabrication for Color Tuning and Performance Improving
Hsin-Hung Lu, Chih-Hao Chang and Show-An Chen*
J. Phys. Chem. C, Article ASAP
http://pubs.acs.org/doi/abs/10.1021/jp901334u?prevSearch=PLED&searchHistoryKey=
7.Thermally Cross-Linkable Hole-Transporting Materials for Improving Hole Injection in Multilayer Blue-Emitting Phosphorescent Polymer Light-Emitting Diodes
Michelle S. Liu, Yu-Hua Niu, Jae-Won Ka, Hin-Lap Yip, Fei Huang, Jingdong Luo, Tae-Dong Kim and Alex K.-Y. Jen*
Macromolecules, 2008, 41 (24), pp 9570–9580
http://pubs.acs.org/doi/abs/10.1021/ma801374w?prevSearch=PLED&searchHistoryKey=
8.Golden Metallopolymers with an Active T1 State via Coordination of Poly(4-vinyl)pyridine to Pentahalophenyl-Gold(I) Precursors
Manal A. Rawashdeh-Omary*†, Jos M. Lpez-de-Luzuriaga*‡, Maher D. Rashdan†, Oussama Elbjeirami†, Miguel Monge‡, Mara Rodrguez-Castillo‡ and Antonio Laguna§
J. Am. Chem. Soc., 2009, 131 (11), pp 3824–3825
http://pubs.acs.org/doi/abs/10.1021/ja809585n?prevSearch=PLED&searchHistoryKey=
6.
