ASTM 690-03标准
这样子求助有问题,因为ASTM 有A,B,C,D,E,F
ASTM A 690/A 690M-2007 Standard Specification for High-Strength Low-Alloy Nickel. Copper. Phosphorus Steel H-Piles and Sheet Piling with Atmospheric Corrosion Resistance for Use in Marine Environments , ASTMA690/A690M , ASTM A690/A690M
2 ASTM B 166-2008 Standard Specification for Nickel-Chromium-Iron Alloys (UNS N06600. N06601. N06603. N06690. N06693. N06025. N06045. and N06696)* and Nickel- Chromium-Cobalt-Molybdenum Alloy (UNS N06617) Rod. Bar. and Wire , ASTMB166 , ASTM B166
3 ASTM B 167-2008 Standard Specification for Nickel-Chromium-Iron Alloys (UNS N06600. N06601. N06603. N06690. N06693. N06025. N06045. and N06696)* and Nickel- Chromium-Cobalt-Molybdenum Alloy (UNS N06617) Seamless Pipe and Tube , ASTMB167 , ASTM B167
4 ASTM B 168-2008 Standard Specification for Nickel-Chromium-Iron Alloys (UNS N06600. N06601. N06603. N06690. N06693. N06025. N06045. and N06696) and Nickel- Chromium-Cobalt-Molybdenum Alloy (UNS N06617) Plate. Sheet. and Strip , ASTMB168 , ASTM B168
5 ASTM B 690-2002 Standard Specification for Iron-Nickel-Chromium-Molybdenum Alloys (UNS N08366 and UNS N08367) Seamless Pipe and Tube , ASTMB690 , ASTM B690
6 ASTM C 690-2003 Standard Test Method for Particle Size Distribution of Alumina or Quartz Powders by Electrical Sensing Zone Technique , ASTMC690 , ASTM C690
7 ASTM D 2690-1998(已撤销) Standard Test Method for Isophthalic Acid in Alkyd and Polyester Resins , ASTMD2690 , ASTM D2690
8 ASTM D 3690-2002 Standard Performance Specification for Vinyl-Coated and Urethane-Coated Upholstery Fabrics - Indoor , ASTMD3690 , ASTM D3690
9 ASTM D 4690-1999 Standard Specification for Urea-Formaldehyde Resin Adhesives , ASTMD4690 , ASTM D4690
10 ASTM D 6690-2007 Standard Specification for Joint and Crack Sealants. Hot Applied. for Concrete and Asphalt Pavements , ASTMD6690 , ASTM D6690
11 ASTM D 6900-2003 Standard Test Method for Wet Adhesion of Latex Paints to a Gloss Alkyd Enamel Substrate , ASTMD6900 , ASTM D6900
12 ASTM D 6901-2006 Standard Specification for Artists’ Colored Pencils , ASTMD6901 , ASTM D6901
13 ASTM D 6902-2004 Standard Test Method for Laboratory Measurement of Formaldehyde Evolved During the Curing of Melamine-Formaldehyde-Based Coatings , ASTMD6902 , ASTM D6902
14 ASTM D 6903-2007 Standard Test Method for Determination of Organic Biocide Release Rate From Antifouling Coatings in Substitute Ocean Water , ASTMD6903 , ASTM D6903
15 ASTM D 6904-2003 Standard Practice for Resistance to Wind-Driven Rain for Exterior Coatings Applied on Masonry , ASTMD6904 , ASTM D6904
16 ASTM D 6905-2003 Standard Test Method for Impact Flexibility of Organic Coatings , ASTMD6905 , ASTM D6905
17 ASTM D 6906-2003 Standard Test Method for Determination of Titanium Treatment Weight on Metal Substrates by X-Ray Fluorescence , ASTMD6906 , ASTM D6906
18 ASTM D 6907-2005 Standard Practice for Sampling Soils and Contaminated Media with Hand- Operated Bucket Augers , ASTMD6907 , ASTM D6907
19 ASTM D 6908-2006 Standard Practice for Integrity Testing of Water Filtration Membrane Systems , ASTMD6908 , ASTM D6908
20 ASTM D 6909-2003 Standard Specification for High Temperature and Acid-Resistant Fluorocarbon Terpolymer Elastomer , ASTMD6909 , ASTM D6909
21 ASTM E 1690-2008 Standard Test Method for Determination of Ethanol Extractives in Biomass , ASTME1690 , ASTM E1690
22 ASTM E 690-1998 Standard Practice for In Situ Electromagnetic (Eddy-Current) Examination of Nonmagnetic Heat Exchanger Tubes , ASTME690 , ASTM E690
23 ASTM F 1690-1996 Standard Specification for Humidifiers for Medical Use - Part 1: General Requirements for Active Humidification Systems , ASTMF1690 , ASTM F1690
24 ASTM F 690-1986 Standard Practice for Underground Installation of Thermoplastic Pressure Piping Irrigation Systems , ASTMF690 , ASTM F690
