UL 标准目录
UL20 (General-Use Snap Switches)
UL45 便携式电动工具 (Portable electric tools )
UL94-12 设备和器具部件用塑料材料易燃性的试验 (Test for flammability of plastic materials for parts in devices and appliances )
UL153中英文便携式电灯 (Portable electric luminaires )
UL197 商业电炊事设备 (Commercial electric cooking appliances )
UL207 含制冷剂的非电气部件及附件 (Refrigerant-containing components and accessories, nonelectrical )
UL224 挤压成型绝缘管 (Extruded insulating tubing )
UL244 设备的固态控制装置(Solid-state controls for appliances)
UL248-1-2000低压保险丝(熔断器)第1部分(Standard for Low-Voltage Fuses, Part 1: General Requirements)
UL248-10 (Standard for Low-Voltage Fuses - Part 10: Class L Fuses,)
UL250 家用冰箱和冷冻柜 (Household refrigerators and freezers )
UL291-2000 自动对讲系统 (Automated teller systems )
UL298 便携式电子手提灯 (Portable electric hand lamps )
UL310 电气快速联接接头(Electrical quick-connect terminals)
UL399 饮用水冷却器 (Drinking-water coolers )
UL429 电动控制阀 (Electrically operated valves )
Subject U L 429A, “Outline of Investigation for Electrically Operated Valves for Fire Protection Service,"
UL444 通信电缆 (Communications cables )
UL458 陆上车辆和船用电源变换器及其系统 (Power converters/inverters and power converter/inverter systems for land vehicles and marine crafts )
UL471 商用制冷机和冷藏柜 (Commercial refrigerators and freezers )
UL474 减湿器 (Dehumidifiers )
UL484 房间空调器 (Room air conditioners )
UL486A 使用铜导体的电线连接器和焊片
UL486C 绞接接线器 (Splicing wire connectors )
UL486E 铝和/或铜导线用设备布线终端 (Equipment wiring terminals for use with aluminium and/or copper conductors )
UL489 模制断路器,模制开关器和断路器外壳 (Molded-case circuit breakers, molded-case switches, and circuit-breaker enclosures )
UL489A 用于通信设备上的断路器
UL496(中英文) 螺口灯座(爱迪生灯座) (Edison-base lampholders )
UL497A 通信电路的辅助保护装置 (Secondary protectors for communication circuits )
UL498连接插头和插座 (Attachment plugs and receptacles )
UL499 电加热装置 (Electric heating appliances )
UL507 电扇 (Electric fans )
UL746A 聚合材料.快速性能评定 (Polymeric materials - Short term property evaluations )
UL746C 电气设备评定用聚合材料 (Polymeric materials - Use in electrical equipment evaluations )
UL758 设备的布线材料 (Appliance wiring material )
UL817 电线集和电力供给电线 (Cord sets and power-supply cords )
UL859 家庭个人修饰用电器 (Household electric personal grooming appliances )
UL935中英文荧光灯镇流器 (Fluorescent-lamp ballasts )
UL1012 除2级以外的电源设备 (Power units other than class 2 )
UL1018 中文电气养鱼设备 (Electric aquarium equipment )
UL1026 (中英文) 家用电子灶具和食品加工器具 (Electric household cooking and food serving appliances )
UL1077 (中英文) 用于电气设备上的附加保护器的标准(Supplementary Protectors for Use in Electrical Equipment)
UL1278 (Standard for Movable and Wall- or Ceiling-Hung Electric Room Heaters)
UL1310A(中英文) 2级电源设备 (Class 2 power units )
UL1446 绝缘材料系统.总则 (Systems of insulating materials - General )
UL1570 荧光灯设备(Fluorescent Lighting Fixtures)1997版
UL1581 电线、电缆和软线的参考标准 (Reference standard for electrical wires, cables, and flexible cords )
UL1585 2类和3类变压器 (Class 2 and class 3 transformers )
UL1642-1 -2 -3 -4 UL standard for safty for lithium Batteriy锂电池
UL1659 塞绳装置和电源线用连接插头刀形开关 (Attachement plug blades for use in cord sets and power-supply cords )
UL1693 电辐射加热板和加热板组件 (Electric radiant heating panels and heating panel sets )
UL1778 不间断电源配送设备 (Uninterruptible power supply equipment )
UL1786 夜间照明灯具 (Nightlights )
UL1977 数据、信号、控制和电源用元件连接器 (Component connectors for use in data, signal, control and power applications )
UL1993 自镇流灯泡及其适配器 (Self-ballasted lamps and lamp adapters )
UL2054 家用和商用蓄电池组 (Household and commercial batteries )
UL2111-1997.3 电动机用过热保护装置 (Overheating protection for motors )
UL2111-2002 电动机用过热保护装置 (Overheating protection for motors )
UL6500 家用、商用及类似用途的音频、视频和音乐装置(Standard for Audio/Video and Musical Instrument Apparatus for Household, Commercial, and Similar General Use)
UL60950 ( 中文 ) 信息技术设备的安全 (Safety of information technology equipment )
