原文由 lizhongyuan5(lizhongyuan5) 发表:
求助渗透性测试的系列标准
D 4050 Test Method (Field Procedure) for Withdrawal and Injection Well Tests for Determining Hydraulic Properties of Aquifer Systems
D 4105 Test Method (Analytical Procedure) for Determining Transmissivity and Storage Coefficient of Nonleaky Confined Aquifers by the Modified Theis Nonequilibrium Method
D 4106 Test Method (Analytical Procedure) for Determining Transmissivity and Storage Coefficient of Nonleaky Confined Aquifers by the Theis Nonequilibrium Method
D 4630 Test Method for Determining Transmissivity and Storativity of Low-Permeability Rocks by In Situ Measurements Using the Constant Head Injection Test
D 4631 Test Method for Determining Transmissivity and Storativity of Low Permeability Rocks by In Situ Measurements Using the Pressure Pulse Technique
D 5269 Test Method (Analytical Procedure) for Determining Transmissivity of Nonleaky Confined Aquifers by the Theis Recovery Method
D 5270 Test Method (Analytical Procedure) for Determining Transmissivity and Storage Coefficient of Bounded, Nonleaky, Confined Aquifers
D 5472 Test Method for Determining Specific Capacity and Estimating Transmissivity at the Control Well
D 5473 Test Method (Analytical Procedure) for Determining the Ratio of Horizontal to Vertical Hydraulic Conductivity in a Nonleaky Confined Aquifer
D 5716 Test Method to Measure the Rate ofWell Discharge by Circular Orifice Weir
D 5786 Test Method (Field Procedure) for Constant Drawdown Tests in Flowing Wells for Determining Hydraulic Properties of Aquifer Systems
D 5850 Test Method (Analytical Procedure) for Determining Transmissivity, Storage Coefficient, and Anisotropy Ratio from a Network of Partially Penetrating Wells
D 5920 Test Method (Analytical Procedure) for Test of Anisotropic Unconfined Aquifers by the Neuman Method
求助渗透性测试的系列标准
求助渗透性测试的系列标准
原文由 仙豆(elixirqin) 发表:原文由 lizhongyuan5(lizhongyuan5) 发表:
求助渗透性测试的系列标准
求助渗透性测试的系列标准
求助渗透性测试的系列标准
