The Skewness and Kurtosis is very important to indentify the surface 對稱性 and 集中性. From statstatic analysis,there are parameters to quantative the surface feature. For example, fratal, Gemometry...
For surface feature analysis, there are a lot of parameters. But no manaual can explain this well. Even traditional roughness, Ra, Rq...Please be advise Ra, Rq is wothout lateral information. If you want to define your surface with X,Y and Z togther. Ra, Rq can not do this.
