参考:分离柱 DB-5ms 0.25mml.D.*X30m |
膜厚 0.25μm |
注入:提取液,2ul |
注入口温度:250℃ |
柱温:60℃(2min), |
25℃/min 125℃(0min), |
10℃/min 300℃(10min) |
进样方式:不分流进样 |
接触面温度:280℃ |
离子化电压:70ev |
检测器增益:1.0KV |
输送气体:线速度 |
柱流量:1.0ml/min |
原来 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 平均值 | 标准偏差 | CV变异系数 |
Dichlorvos | 1.93316 | 3.41367 | 4.0878 | 3.89776 | 3.74188 | 3.65186 | 4.21677 | 4.2474 | 4.07774 | 4.29788 | 3.756592 | 0.701752 | 18.68% |
Methamidophos | 2.07056 | 3.74654 | 4.91035 | 4.93344 | 4.72814 | 4.32029 | 5.62108 | 5.24801 | 5.16194 | 5.69306 | 4.643341 | 1.074084 | 23.13% |
.gamma.-BHC | 2.29898 | 4.09486 | 4.98562 | 4.71422 | 4.7047 | 4.41616 | 5.18611 | 4.96787 | 4.79978 | 5.1761 | 4.53444 | 0.854013 | 18.83% |
Chlorpyrifos | 2.29979 | 4.09762 | 5.05808 | 4.79633 | 4.67647 | 4.55297 | 5.34405 | 4.9549 | 4.92748 | 5.39546 | 4.610315 | 0.895563 | 19.43% |
Dieldrin | 8.55844 | 14.63842 | 18.35049 | 17.33014 | 16.7197 | 16.5397 | 18.58038 | 17.02737 | 16.99411 | 18.1744 | 16.29132 | 2.942325 | 18.06% |
o,'p-DDT | 3.51722 | 6.13439 | 7.70653 | 7.30441 | 7.05259 | 7.19289 | 8.41101 | 7.68599 | 7.54761 | 8.32704 | 7.087968 | 1.412481 | 19.93% |
Triazophos | 14.35048 | 24.5182 | 32.08463 | 30.82784 | 29.83541 | 31.53666 | 35.9025 | 31.87203 | 32.64416 | 34.76548 | 29.83374 | 6.237396 | 20.91% |
Fenpropathrin | 2.0801 | 3.51223 | 4.39037 | 4.15241 | 4.03711 | 4.2354 | 4.78521 | 4.36397 | 4.32709 | 4.61245 | 4.049634 | 0.771925 | 19.06% |
Cypermethrin-1 | 1.23284 | 2.21685 | 3.02853 | 2.91241 | 2.81342 | 3.09452 | 3.32532 | 2.96217 | 3.06687 | 3.10495 | 2.775788 | 0.6154 | 22.17% |
Cypermethrin-2 | 1.83529 | 3.18992 | 4.29173 | 4.09187 | 3.93827 | 4.30534 | 4.643 | 4.10886 | 4.23116 | 4.25526 | 3.88907 | 0.813335 | 20.91% |
Fenvalerate-1 | 1.81903 | 3.02074 | 4.04114 | 3.72512 | 3.56224 | 3.81872 | 4.04634 | 3.51761 | 3.68917 | 3.73617 | 3.497628 | 0.657826 | 18.81% |
Fenvalerate-2 | 1.28389 | 2.13354 | 3.25666 | 2.91634 | 2.68691 | 3.00821 | 3.13496 | 2.55771 | 3.08788 | 2.82517 | 2.689127 | 0.591839 | 22.01% |
