主题:【讨论】帕纳科顺序式X荧光高压安全灯关闭报警信息的分析
浏览0 回复3 电梯直达
xingwenqing
帕纳科顺序式X荧光高压安全灯关闭报警信息的分析,可按附件查找属于因哪个原因引起的然后进行下一步处理
附件:
Onway
0.        Safety error (In this case the <HW_mod_nr> indicates the SwitchOff reason)
1.        mA ready timeout
2.        kV ready timeout
3.        X-Ray tube flashed during startup
4.        X-Ray safety LAMPS-ON timeout
5.        Mains DC level timeout
6.        Anode cool. circ.: Flow timeout
7.        Cathode cool. circ.: Flow timeout
8.        Anode cool. circ.: Conductivity timeout
9.        Anode cool. circ.: Temperature timeout
10.        X-Ray-ON keys are off
11.        Safety bellows not OK
12.        X-Ray lamps not OK
13.        Temperature in generator too high
14.        Mains supply not OK
15.        Anode cool. circ.: Level too low
In case of a Safety error, the <HW_mod_nr> contains the SwitchOff reason:
40.        Not off
41.        Reason unknown The switchoff reason has disappeared already and can not be determined anymore (For example: water temperature too high)
42.        Safety Circuit not ok (In this case the <HW_err> indicates the NotSafeReason)
43.        mA timeout
44.        kV timeout
45.        Flash at startup
46.        MDC timeout
47.        Breeding failed. Breeding has been aborted due to too many flashes
48.        Flashed too often
49.        Commanded by user. Tube has been switched off by the user
50.        Medium is air
51.        Mobility kit. The breaks of the mobility kit are off
52.        Turret timeout. The turret has not been initialized successfully. Therefor the tube may not be switched on due to radiation safety.
53.        Cap open timeout. Because of a cap open timeout the tube has been switched off in order to protect samples (eg liquid samples)
54.        Cap close timeout. Because of a close timeout the tube has been switched off in order to protect samples (eg liquid samples)
55.        Plunger up timeout. Because of a plunger up timeout the tube has been switched off in order to protect samples (eg liquid samples)
56.        Plunger down timeout. Because of a plunger down timeout the tube has been switched off in order to protect samples (eg liquid samples)
57.        Tube filter timeout. Because of a  timeout of a tube filter movement the tube has been switched off in order to protect samples (eg liquid samples)
58.        Bad vacuum. When the medium is vacuum, going to vacuum, unknown or vacuum leaktest and the vacuum level is higher than 1000 Pa, the tube has been switched off in order to prevent corrosion. (PW2830 only)
看你报警这么多!是最近发生的?
若是,估计是高压发生器出现故障了!
相逢何必相识
xingwenqing
可能我的意思没表达清楚,(我将光管关闭报警信息代号告诉大家,方便大家寻找原因)如43.                mA timeout(是因为电流超时)
