Diffusion-ordered NMR spectroscopy(DOSY) is a powerful tool to analyse the composition of a complex mixture based on the diffusion behaviour of the certain moleculars under the pulse-field gradients. The employment of the diffusion dimension in addition to a conventional chemical shift NMR dimension provides high resolution of NMR data.
