主题:整理热分析ASTM标准目录,欢迎提供相关ISO标准
浏览0 回复12 电梯直达
cdjinjiancom
该帖子已被穿越时空设置为精华; 奖励积分记录: 穿越时空(3分)
热分析ASTM标准目录
这是我整理的热分析ASTM标准目录,哪位能够提供相关ISO标准或目录?
METHOD TITLE
D2116-97 FEP - Fluorocarbon Molding and Extrusion Materials
D3159-98 Modified ETFE-Fluoropolymer Molding and Extrusion Materials
D3222-99 Unmodified Poly(Vinylidene Fluoride) (PVDF) Molding Extrusion and
Coating Materials
D3275-00 E-CTFE Fluoroplastic Molding and Extrusion Materials
D3307-00 PFA - Fluorocarbon Molding and Extrusion Materials
D3350-01 Polyethylene Plastic Pipe and Fitting Materials
D3386-00 Coefficient of Linear Thermal Expansion of Electrical Insulating
Materials
D3417-99 Heats of Fusion and Crystallization of Polymers by Thermal Analysis
D3418-99 Transition Temperatures of Polymers by Thermal Analysis
D3850-94 Rapid Thermal Degradation of Solid Electrical Insulating Materials by
Thermogravimetric Methods
D3895-98 Oxidative Induction Time of Polyolefins by Thermal Analysis
D4000-01 Identification of Plastic Materials
D4065-95 Determining and Reporting Dynamic Mechanical Properties of Plastics
D4066-01A Nylon Injection and Extrusion Materials
D4092-96 Definitions and Description of Terms Relating to Dynamic Mechanical
Measurements of Plastics
D4101-01 Polypropylene Plastic Injection and Extrusion Materials
D4181-00 Acetal (POM) Molding and Extrusion Materials
D4419-00 Transition Temperatures of Petroleum Waxes by Differential Scanning Calorimetry
D4441-98 Aqueous Dispersion of Polytetrafluoroethylene
D4485-01 Specification for Performance of Engine Evaluation of Diesel Engine Oil
D4565-99 Physical and Environmental Performance Properties of Insulations and
Jackets for Telecommunications Wire and Cable
D4591-01 Temperatures and Heats of Transition of Fluoropolymers by DSC
D5028-96 Curing Properties of Pultrusion Resins by Thermal Analysis
D5483-95 Oxidative Induction Time of Lubricating Greases by PDSC
D5885-97 Oxidation Induction Time of Polyolefin Geosynthetics by PDSC
D5967-99A Evaluation of Diesel Engine Oils in T-8 Diesel Engine
D6186-98 Oxidation Induction Time of Lubricating Oils by PDSC
D6370-99 Rubber Compositional Analysis by TGA
D6375-99A Evaporation Loss of Lubricating Oils (NOACK) by TGA
D6382-99 DMA and TGA of Roofing and Waterproofing Membrane Materials
D6483-99 Evaluation of Diesel Engine Oils in T-9 Diesel Engine
E0473-00 Terminology Relating to Thermal Analysis
E0487-99 Constant Temperature Stability of Chemical Materials
E0537-98 Assessing the Thermal Stability of Chemicals by Means of DTA
E0698-99 Arrhenius Kinetic Constants for Thermally Unstable Materials
E0793-01 Heats of Fusion and Crystallization by DSC
E0794-01 Melting and Crystallization Temperatures by Thermal Analysis
E0831-00 Linear Thermal Expansion of Solid Materials by TMA
E0928-01 Mol Percent Impurity by DSC
E0967-97 Temperature Calibration of DSCs and DTAs
E0968-99 Heat Flow Calibration of DSCs
E1131-98 Compositional Analysis by TGA
E1142-97 Terminology Relating to Thermophysical Properties
E1231-01 Hazard Potential Figures-of-Merit for Thermally Unstable Materials
E1269-01 Specific Heat Capacity by DSC
E1356-98 Glass Transition Temperatures by DSC and DTA
E1363-97E1 Temperature Calibration of TMAs
E1545-00 Glass Transition Temperatures by TMA
E1582-00 Temperature Scale Calibration of TGAs
E1640-99 Glass transition Temperature by DMA
E1641-99 Decomposition Kinetics by TGA
E1782-98 Vapor Pressure by DSC and DTA
E1824-96 Glass Transition Temperature by TMA in Tension
E1858-00 Oxidative Induction Time of Hydrocarbons by DSC
E1860-97A Time Base Calibration of Thermal Analyzers
E1867-97 Temperature Calibration of DMAs
E1868-97 Loss-on-Drying by TGA
E1877-00 Thermal Endurance of Materials from TGA Decomposition Data
E1952-01 Thermal Conductivity and Diffusion by MDSC
E1953-98 Description of Thermal Analysis Apparatus
E1970-01 Statistical Treatment of Thermal Analysis Data
E2008-99 Volatility Rate by TGA
E2009-99 Oxidation Onset Temperature by DSC
E2038-99 Temperature Calibration of DEAs
E2039-00 Dielectric properties by DEA
E2040-00 Mass Calibration of TGAs
E2041-99 Borchardt and Daniels Kinetics by DSC
E2046-99 Reaction Induction Time by DSC
E2069-00 Temperature Calibration on Cooling of DSCs
E2070-00 Isothermal Kinetics by DSC
E2071-00 Heat of Vaporization
E2092-00 Distortion Temperature in 3-Point Bending by TMA
E2113-00 Length Change Calibration of TMAs
F2004-00 Transformation Temperatures of Nickel-Titanium Alloys
F2005-00 Terminology for Nickel-Titanium Shape Memory Alloys
您可能想找: 热重分析仪/热天平(TGA) 询底价
hereyouare
这些没找到
Last edit by hereyouare
hereyouare
上传附件太慢了,我就放在mofile里了
谁那里快再上传到论坛吧
您上传的文件:
大小 文件名
5M  DSC ASTM 标准.rar
已经成功地保存在Mofile
文件提取码: 7967959897516051
    当您的朋友需要提取此文件时只需:
    匿名提取文件连接 http://pickup.mofile.com/7967959897516051
    或登录Mofile,使用提取码 7967959897516051 提取文件
cdjinjiancom
cdjinjiancom
boywy000
boywy000
原文由 wuyiqin517 发表:
太板杂了.能看全文吗?
这些对我非常有用.
全文在我跟贴的附件里~~
boywy000
原文由 lee214 发表:
你的附件现在不能下载了呀,能重新让下载吗
ASTM标准
我重新上传一次,楼上看看是否能够下载~~
附件:
zjzxwwl2a
这里ASTM标准目录有不少,也来看看我的ASTM标准目录: http://www.instrument.com.cn/download/search.asp?sel=admin_name&keywords=zjzxwwl2a
tail-007
lemonq
