原文由 hittl(hittl) 发表:
最近测试了两个样品的电化学阻抗谱图,用版上大家介绍的方法进行拟合,却始终得不到满意的结果,现求助于版上的高手帮忙看看我的结果能不能按图上(Figure 2)的模型进行很好的拟合,谢谢了!附件是sample1和sample2的原始数据。
我的样品是graphene-based composite,.5 mM K3[Fe(CN)6]/K4[Fe(CN)6] as redox probe and 0.1 M LiClO4 was employed as the electrolyte.The EIS was performed with amplitude of 10 mV in the frequency range from 10 KHz to 0.1 Hz.
