leeman是主要的ICPAES生产商之一。虽然原理上是扫描型的仪器,但profile系统采用专利的技术是检测器移动而非波长扫描。具体信息请与其北京办事处联系:68317070,68344195。<br>
<br>
Leeman Labs, Inc. has manufactured Inductively Coupled Plasma Optical Emission Spectrometers (ICP-OES) since 1981. Our ICP spectrometers are designed to deliver the performance that analysts demand, day in and day out. The Profile Plus ICP comes in axial, radial and dual view configurations; choose the configuration best suited to your analytical requirements.<br>
<br>
Features that make a difference:<br>
<br>
High Resolution<br>
<br>
Minimizes spectral interferences for superior accuracy and improved analytical performance <br>
Eliminates the need for almost all troublesome inter-element corrections <br>
Full wavelength coverage (170-780nm) <br>
Fully Automated <br>
<br>
All operating parameters are computer controlled including sample handling with built-in autosampler <br>
On-peak Measurements<br>
<br>
Fast, accurate measurements <br>
Analysis does not require peak searching which is prone to selecting incorrect wavelengths <br>
Compact Benchtop ICP <br>
<br>
Lab space is expensive. The Profile Plus ICP is self-contained and fits comfortably on a standard lab bench <br>
Axial, Radial or Dual View Optics<br>
<br>
Axial view can improve detection limits by 5-20x <br>
Radial view can handle tougher matrices <br>
Dual view allows line-by-line selection of viewing configuration <br>
Auto-Align Torch <br>
<br>
Eliminates variability in torch installation and alignment <br>
Rugged RF Generator<br>
<br>
The water-cooled 40.68 MHz free-running RF generator is long lived and provides <br>
superior tolerance to a wide variety of sample types including high solids and volatile organics <br>
WinICP Software<br>
<br>
Easy-to-use, designed for Windows® 95, 98, 2000, ME and NT. <br>
Qualitative, fast semi-quantitative, and quantitative analysis <br>
On-line help <br>
Built-in maintenance scheduler <br>
